Question about Canon PIXMA MP760 All-In-One InkJet Printer
I have a Canon MP760. After a few years of use, I got an alarm that warned me that the Waste Ink Absorber was nearly full. I tried to ignore it for a while, but it kept erroring, and I'd have to clear it. Finally, I took the printer apart enough, to find, remove and clean the absorbers. After I reassembled the printer, I was back where I started. I found out on the Canon site, that there is a counter in the printer that records the number of pages printed, and that it needs to be reset, before your printer works as though it had no ink absorber problem. Canon refused to tell be how to do this. I hope you can help me. I have a background of computer and terminal repair, but I don't know enough about Canon printers, to go blindly poking around in the logic. I'm hoping that there is a code that I can send to the printer from my computer, that will reset the counter. Thanks for reading this, and hopefully telling me how to fix the printer. Terry C. - Tacoma, WA, 253-564-9390 Terry C. - Tacoma, WA 253-564-9390
  • 1 more comment
  • tattercc Oct 12, 2010
    Adnanbhatti,
    I can get as far as going into the service mode, selecting "7", then "5", but I can't figure out how to select and OK "0". So I'm back to where I started, since I apparently didn't get the counter zeroed.
    Terry C
  • tattercc Oct 13, 2010
    Bob, please note that I have a PIXMA MP760. I have successfully cleaned the absorbers, but the "counter" is still causing it to alarm due to being "almost full". I need to reset the counter to zero, but am unable to figure out how to enter a "zero" from the Menu/copy/scan/copy7/5 input. Please tell me how to enter a zero from this point.
    Terry C
    Adnanbhatti,
    I received your reply to my "zero" question. Your answer seemed to say that I have a numeric keyboard on my printer. If there is, I can't locate it.
    Did you mean that I need to "talk" to the printer via my computer? Should I have the computer connected to the printer? If so, how to I type directly to the printer from my computer?
    Terry C
    President:
  • 2,653 Answers
Hi Terry,
Here's a link to a service manual. It details how to reset the counter step-by-step.
Hope this info helps ;)
Posted on Oct 14, 2010
  • 3,153 Answers
Everything you should need to know is here
http://www.fixyourownprinter.com/forums/inkjet/41348
or here
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
For the most part the instructions do vary from one Cannon to another but the process is almost always similar and trying to post suitable pictures on FixYa is always a hit and miss affair hence the reasons for sending you to other sites.
Bob
Posted on Oct 13, 2010
    President:
  • 1,188 Answers
Normally this information is not shared with the end user because a faulty key press in the service mode can ruin the machine and void the warranty. But as you have already cleaned the ink pads, I assume that you have the expertise to undertake the risk.
By continuing below you assume full responsibility of printer damage in case of faulty input. Do not attempt if unsure.
It can be done as follows:
Push these buttons in a relativity fast sequence (not all at same time!): menu > scan > copy > scan. choose the "test mode". Press to go to 7 and then select 5 then input "0",press OK and wait a while until the process message changes. Switch your printer off an on again. That is it. Notice: If you don´t exchange the old absorber pads you may find one day wasted ink coming out under your printer.
Just for you: link to service manual! (pdf file)
Posted on Oct 12, 2010
  • Adnan Bhatti
    Adnan Bhatti Oct 13, 2010
    Input "0" with the numeric keys.
Canon PIXMA MP760: Waste Ink Absorber almost full - interrupts printing. Removed/cleaned absorbers. Still "almost full". I found out that there is a counter, versus a sensor, that determines the state of...
I'm curious as to how you cleaned the ink absorbers since they are normally sealed.
Go to the Cannon USA website and search using the terms full ink absorbers and MP760.
Let me know if you still cannot find the answer.
Oct 15, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Canon mp760 printer overflow full, have parts and service manual. Need code to get going again
there is no need to change the ink absorbing sponges at all ,,as i hve solved this problem myself for many of my clients i m sure that it will work for u too if followed properly step by step:
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
reset sequence for a MP760 printer that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
ur printer absorber will reset and will work properly and u will be back to work.try doing it one more time if u miss something .
please take a moment to rate the solution after u get ur problem solved
Oct 03, 2008 | Canon PIXMA MP760 All-In-One InkJet...
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Where is the waste ink tank?
Dec 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer won't print. Says to contact service
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
167 people viewed this question
old marine
old marine
