Question about Rheem Water Heaters
Rheem Integrity 24 showing code C9 - 11 - Rheem Water Heaters
4 Suggested Answers
  • 11 Answers
SOURCE: Water leaking by drop from my Rheem Integrity 24
Where is the leak? be careful looking...ELECTRICAL wires inside...water and electric and YOU DON'T mix
Posted on May 20, 2010
  • 68 Answers
SOURCE: Rheem Integrity 24 Has Error LO79 can someone tell
79 is fan motor current fault or circuit board you will have contact rheem
Posted on Aug 12, 2010
SOURCE: Rheem Integrity 20 not always lighting. Showing
Before calling service technician, open following links for Rheem/Paloma troubleshoot resources including error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
C2 11 is no ignition.
Clean combustion parts yearly as recommended in manual is first step.
Other causes can be loose wiring, bas gas valve, dirty air intake, bad venting, bad sensors etc.
Test these parts using service manual. Call Rheem since Rheem does not post service manuals.
Posted on Oct 08, 2011
Keeps coming up c4 56
Usually tankless computer water heaters are not repairable by homeowner... or anyone else if unit is older than 6 years.
Smae applies to laptop computers, telephones, garage door openers and other computer-chip operated devices.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Mar 17, 2014 | Rheem Tankless Hot Water Heater...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
Rheem Integrity 20 not always lighting. Showing code C2 11
Oct 06, 2011 | Rheem Tankless Hot Water Heater...
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are considered start-point for troubleshoot.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Jun 07, 2010 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
94 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
