Question about B&K Plumbing
I have a B&K LM 203120 single control faucet. I am searching for a parts/disassembly diagram.
5 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: My single control faucet is leaking on the side,
Kohler should provide you with a rebuild kit for free. Contact them at 1-800-4KOHLER. This is the parts breakdown for your Kohler faucet.
Posted on Sep 10, 2010
bearsfan7538
  • 119 Answers
SOURCE: HOW TO FIX LEAK ON AMER. STANDART SINGLE CONTROL
Replace the cartridge
Posted on Nov 28, 2009
jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
SOURCE: water leaking from bottom part of the faucet
I had a similar problem with my relatively new Forte model. I disassembled the handle, removed the retaining ring and the valve assembly. I thought at first it was the valve assembly but wasn't convinced. I continued to remove the entire faucet hub by gripping and pulling straight up. When I did, the diverter valve popped out of the back to the counter behind the sink. I cleaned all the parts up, made sure all the rings were in place, presse the diverter securely into place back in its hole, and reassembled the rest of the parts. That seemed to do the trick. I'm guessing that the diverter lost its seal and was displaced inside the hub. Hope that helps someone else.
Posted on Oct 27, 2010
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
How do you install part gp75878
You need patience/care to open up the faucet and replace the parts.
See if you can understand the diagram on page 15 of the installation guide. The link to the guide is:
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1084448_2.pdf
Jan 28, 2014 | Kohler Model 10430: Fort® Single-control...
Hello- I have a Kohler Fairfax single lever faucet that has suddenly become very sticky in all directions. I have removed the faucet handle and applied silicone plumbers grease to the white plastic seal....
It just needs some TLC and possibly a new valve (cartage) the link below should help.
http://www.us.kohler.com/onlinecatalog/pdf/1097759_2.pdf
Disasemble the and clean. I would just get the new rebuild ket and make it like new on the inside.
FYI that kit is kind of pricy so if the faucet is not in good condition on the outside you might want to just pick a new one that you like better.
Feb 04, 2011 | Kohler Fairfax Single Control Lavatory...
Water barely comes out hot or cold
Make sure the filter screen that is screwed to the spout is clean and in properly. If so there may be debris in the ball control valve. If the faucet has some age on it, I suggest going to Home Depot and getting a rebuild kit. The kit contains disassembly instructions and all new valve parts. Easy fix and HD is a Price dealer. Thanks
Jan 08, 2011 | Price Pfister Single Lever Handle Faucet...
I have a B&K kitchen faucet (LM#203120) in my 2005 Newmar motor home. The spray wand has recently broken. The spray wand is approximately 6.5 inchs long and is connected to the water line by means...
If you are talking about the standard spray nozzel with trigger type control than replacement sprayers are reaidily available. You should be able to unscrew flex hose from nozzel at the base of nozzel where sprayer goes into holder on sink.There should be ribbed section on sprayer where flex hose goes in. Grip that section and turn upper section of sprayer counterclockwise to remove. Most hardware stores will have replacement nozzels for under ten dollars. Hope this helps. Thanks
Nov 12, 2010 | B&K Plumbing
Water leaking from bottom part of the faucet ...not sure if the model is a 10433 Fort Single control pullout
Jul 26, 2010 | Kohler Model 10433: Fort® Single-control...
Need technical diagram of single hole faucet
Not sure where to find the diagram, but what type of faucet is it and where is it leaking? It it's a single lever, remove the hot/cold indicator to uncover an allen set screw. Loosen it and remove the lever, then the outer bushing nut. Now you'll have access to the interior parts around the cartridge (make sure you turn the water off to the supply lines before proceeding further). If it's the two handle type, remove the index buttons from the top of each handle to uncover a screw with either a slotted or phillips head. Remove the screws and remove the handles. You now have access to the valves and seats. If it's a 12-year-old faucet, the o-rings and seats will probably need to be replaced and this will fix your problem. If it's a single lever type, you'll need to replace the seats and springs and it will probably solve the problem.
Jun 14, 2009 | Grohe 40367000 Chrome Accessories Single...
Plumbing Logo
768 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
