Question about Whirlpool Washing Machines
I have a Whirlpool washer - M/ WFW8400tw02,,, I push the power and the door locks nothing happens... after about 5 mins the power goes off and the door unlocks. No codes,, just powers up then power goes off. no wash.
duby1990
  • 370 Answers
SOURCE: Whirlpool duet front load washer, DFL code
Here are the steps to unlocking the door manually
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Posted on Nov 21, 2008
Krazytech
  • 725 Answers
SOURCE: WHIRLPOOL DUET WASHER 9150 DOOR LOCK DOES NOT UNLOCK
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
replace door lock and ccu sorry
Posted on Jul 28, 2008
  • 530 Answers
SOURCE: Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Posted on Jan 04, 2009
  • 63 Answers
SOURCE: Whirlpool Duet Sport Washer won't start, Error code F-01
your main control board is bad,easy to replace //jc//
Posted on Jan 20, 2009
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
Whirlpool cabrio washer WTW5500XW1. Washer starts then lid lock starts blinking and nothing happens.
Bad lid lock activator....try taking some contact spray...and open lid find contact that goes up and down in lid closing area ...spay contact spray then open and close lid 5 times and try it...
Aug 13, 2016 | Whirlpool Washing Machines
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
The power went off while i was washing. now that the power is back on my washer lid is still locked. I pushed the start pause button but nothing happened. I shut it off and restarted it and still...
Hi
What you can try to do is unplug washer for one minute and then power it up choose a cycle and you should hear the door mechanism unlocking
hope this helps
Mar 27, 2011 | Whirlpool Washing Machines
WHEN I PUSH THE START, NOTHING HAPPENS,NO NOISE AND THE DOOR DOES NOT LOCK. IF I PUSH THE CLEAR BUTTON TWO -- WILL APPEAR AND STAY FOR ABOUT 30 SECONDS AND THEN A BLANK DISPLAY. UNPLUGGED WASHER FOR 5 MIN....
if you had a power failure latly or a power surge it might have knocked the program on the machine.Push and hold the stop/start button for about 10,seconds it should reset if that fails again hold the stop button and another ie rince hold/power save or whatever buttons you have i just cant remember which one there are so many,but try the first option first it should reset.adrian,,,,,,,,
Aug 15, 2010 | Kenmore 44072 Front Load Washer
Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Washer won't start door locked
Likely the ECU is failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Door locked & nothing happens Whirlpool duet wfw8300sw01
hi there,
sounds like the machine has no power at all.
there was no need to break the lock.
unplug the machine
take off the console
check connections from the touchpad to the CCU board
make sure nothing is corroded, burned, bent or pinched
unplug and replug the wiring harness
plug the machine back in and try it again.
let me know if this works.
Sep 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet front load washer control locked--How do I undo??
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
52 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
