Question about HP PSC 2355 All-In-One InkJet Printer
Wont print error message 165:hw_interrupt_hwv2.c also 0xb9000001
  • 340 Answers
Follow this link and select your Operating System. Go through the steps listed. You may need to completely uninstall your printer and reinstall. If you do not have your installation cd you can also get that from this website. Let me know if this helps
Lori
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02251801&lc=en&dlc=en&cc=us&product=422000
pls leave rating if at all helpful, thanks!
Posted on Oct 12, 2010
3 Suggested Answers
  • 375 Answers
SOURCE: wont print error message 165:hw_interrupt_hwv2.c also 0xb9000001
The error is indicative of a hardware error.
Remove the power cord, hold # + 6 (semi-full reset) or # + 9 (full reset) buttons, then connect the power cord again, wait 3 secs (or until "Initializing Full Reset" appears on the printer display) and release the buttons.
This will set the printer configurations to its factory defaults.
Reset: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 3
Underware menu: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 4
Clear and reset NVM RAM: Press and hold OK and Cancel while plugging in the power cord.
If none of those work, it will need to be returned to HP as a failed unit.
Posted on Jun 29, 2009
I moved the printer to a different area of living rooom, and when I plugged it back in now I get this same thing happening! I can't turn off power, and do anything.
Posted on Sep 06, 2009
H-400 error on Sharp 165
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 29, 2015 | Sharp Office Equipment & Supplies
HP PSC 2355 is stopping in the middle of printing. Then can't even get it to turn off. message )xb984489d and 165 hw interrupt_hwv2.c Can you help?
Just fixed a HP PSC 2355 that had this problem. Turned out it was caused by dried out electrolytic capacitors on the printer circuit board. You can check it yourself by carefully removing the plastic cover around the power / USB connectors and then blowing warm air in to the opening with a hair-dryer for a couple of minutes. If everything's working now, you probably have faulty capacitors. Exchanging them is another matter entirely, don't attempt this unless you have a good working knowledge of electronics!
Mar 31, 2011 | HP PSC 2355 All-In-One InkJet Printer
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
I am facing F2-04 error code in sharp AR-M 165
# - interrupt- C - Interrupt -press 16 press Print key then machine is ready.
Feb 12, 2010 | Office Equipment & Supplies
Error u2
Press #, Interrupt, C, Interrupt. Enter 16 print.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
Sharp sf 2040 error code F1-02
If the sorter has a problem, disable that option by command 26 print 01 print and enter 0 enter.
Apr 05, 2009 | Sharp SF 2040 Copier
I have LG dishwasher model LD 14AW1 I get error the message HE about 15 minutes into the wash cycle then the dishwasher turns its self off
HE refers to HEATER ERROR
The water is not heated
or the temperature in
the Tub is overheated
to over 95¡
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Feb 22, 2009 | LG 24 in. LD-12BW5 Free-standing...
Feb 09, 2009 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
415 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
