Question about Nokia N73 Cellular Phone
I dont get call summary while call is in progress
I dont get call summary while call is in...
Posted on Nov 11, 2010
How do i unlock my ipod touch when i forgot my password and i dont want to restore it
You can unlock your IPOD Touch passcode or password by following these simple steps:
•Connect your IPOD Touch to iTunes
•Press or Hold the power and home keys for 10 seconds.
•Screen goes black, now release the power button
•Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
•After this its simple all you need to do is a restore using your iTunes.
Restore an iPod:
Warning: When you restore and iPod, you delete everything on it (songs, pictures, movies, files, games, firmware, etc.) Hey! That means any stuff that's on the iPod, but not in the iTunes library, will be lost. After deleting everything, iTunes reloads the iPod software with a fresh copy (referred to as "factory settings").
Using iTunes:
When the iPod is connected, select it in the Source list in iTunes. Under the Summary tab, there is a button named "Restore." Click it. Select the restore option you want then sit back. A progress bar will show you the status of the restore. When it's done, you'll see a message like "Leave iPod connected to computer to complete restore." Now the iPod will show a progress bar. Do not disconnect during this part. When it's done, the iTunes Setup Assistant will prompt you to name and configure the iPod.
Jan 12, 2010 | Computers & Internet
Mavis Beacon Typing Tutor Platinum 20 shows minus wpm in progress summary even though I average 45-50 wpm,
If it's pirated thats your problem. the patch may have changed the wrong bytes in the exe file
If it's not......
try a re-install of the software if that doesn't work i'd send their product support a message at this link
http://www.broderbund.com/store/broder/Content/pbPage.ProductQuestion
Nov 11, 2009 | Encore Mavis Beacon Teaches Typing...
On our Dish 500 we get strong signals on both 110 and 119 but cannot lock on 119.
Hi jmhunsinger! I will be glad to assist you in your concern. 1st let press the reset button on the front panel of the receiver for 10secs, then once its reset, you will see attention 015 this will go on a progress, then press the menu button on the remote, that is on the upper left, then you will see the main menu. once you see the main menu, press 6,1,1 on the remote and it will go to pointdish, once you see point dish, select check switch on the upper right, then it will go to install summary, on the install summary, you will see installed device, input1-110-all, input2-110-all, on the butom you will see test, select test to perform switch test, let the test finish once its done it will be back to install summary, you should see input 1-119, input2-110 and both should be all or odd-even, select cancel, then it will go to pointdish, you will see on the sat field it could be 119 or 110 and under the signal meter you will see there lock echostar, it could be 119 or 110 west, no problem if one of them will show.119 west or 110 west, then selct cancel, then press 0, 3 times on the remote then it will go to attention 015, let the progress finish until it download the programming guide, if you got the tv show, and can change the channels of the program, lets check your sat if both of them is green, press on the remote the menu button and once the mainmenu is up, press on the remote 6, 1, 3 then it will go th the sysinfo, on the field g, you should see there 119-green, 110-green, if there are two green your good to go, but if there is only 1 sat, press cancel then select on the option updates, once your on the updates screen, you should select on with out my permission, then select save, and cancel all the way out, then it will show a tv pic..turn off the receiver by pressing the power button on the remote, then once the power is off, green light on the receiver if off and the tv will show a snowy or black screen, but in a few seconds it should show attention 061, downloading vital program information, this process will update the software of your receiver, let the process finish, dont do anything just sit and relax and wait until it finish, once its done the wtv will be on a black or snowy screen and the message will disappear. press and hold the power button on the receiver for 10secs then it will pop attention 015 let the progress finish until it download the programming guide, once you got a tv show, press again the menu button on the remote and press 6,1,3 on the remote to check sysinfo and check field g if sat 119-green, 110-green. granting still 1 sat and its green, select cancel, select point dish, check switch and test, let it finish once its finish, it should show 2 sat, 119, 110. then cancel all the way out and it go on the process again and wait untill all the process finish. granting you did check on the sysinfo again and still show only 1 sat. if you have other solo receiver, try to hook up the other receiver to the room were your having a problem, run the check and test the switch on the pointdish. lets say that the other receiver got two sat-119 and 110, mean that the 1st receiver that you working at have a problem and it needs to be replace but if the 2nd receiver that you hook up and it shows the same problem, call on 1-800-333-3474 and ask for service tech, there is a problem with your dish 500.
note: replacing the receiver and asking for a tech- you need to call the same number-1-800-333-3474
if you have any query,pls feel free to get in touch
Sep 19, 2009 | DISH Network 301 DTV Receiver
Call summary during the call
not a major prblm because there is no option of call summary on time in any nokia handset
Oct 09, 2008 | Nokia N73 Cellular Phone
Forgot password
You need to restore the itouch, if you are unable to restore please read this page http://support.apple.com/kb/HT1808 do what it says and try restore again.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Jul 31, 2008 | Apple iPod touch
Can not enter ipod because i dont know the enter code can you help.
To get the code removed you have to restore the ipod
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
For Windows:
May 15, 2008 | Audio Players & Recorders
Apple nano
You have to restore it to get it to work again
Restore
For Windows:
May 13, 2008 | Apple iPod nano 3rd Generation
PASWORD TO IPOD NANO
Ah
You need to perform restore to remove the password
For Windows:
May 09, 2008 | Apple iPod nano
Resetting passcode to ipod 2gb
you need to restore your ipod
Restore
How to restore your iPod: For Windows:
For Mac:
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
    • Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
  • 6. A message will appear prompting you to enter an administrator's name and password.
  • 7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Dont forget the rate the solution as fixya!
If you need more assistance let me know, I'm here to help
Apr 04, 2008 | Apple iPod nano
Progressive scan
progressive scan? does your tv support 720p, or 1080p HD? (the p actually stands for progressive scan).
Another alternative to that is: http://www.playerschoicevideogames.com/pd_psp.cfm
A bit more expensive, but i think it works on any tv.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Nokia N73 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
