Question about Ovens
We have the Gallery Series stand alone oven. We were using the oven when the power went out. When the power came back...the oven only beeps and displays the F1 error. Does this mean the board is shot or is there a magic reset button? Thanks ...Steve
  • steve37695 Oct 12, 2010
    Thanks...do you have any recomendations? Franklin TN...outside of Nashville?
  • Ovens Master
  • 11,800 Answers
Sorry, no reset button - there's nothing to reset in that board, it's just a very simple controller that got fried by the power surge. You will have to call a repairman to replace it.
Posted on Oct 12, 2010
  • Azrael SRL Oct 12, 2010
    Sorry, i've never been in your state and i don't know anyone there.
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Tip
Please help. We are a cleaning crew that went to a client's home to do a reno...
If you are having oven problems with your GE XL44 oven then you need to do a bit of oven troubleshooting. The first part of that problem is to know what the oven fault codes are trying to tell you.
The codes F0, F1, and F7 could either be a problem with the control or the keypad.
-to see what the problem is cause by, push clear/off on the keypad. Then disconnect the ribbon connector from the control. Wait at least 35 seconds to see if the code comes back. If the code comes back then the control is the problem. If the code does not come back, then replace the key panel.
F2 – This means there has been a problem with the temperature of your oven. It could be a cooling fan or air flow problem. Also could be that the oven got too hot in either a baking mode or a cleaning mode.
-check to make sure the contactor contacts are not welded together. If this happens the oven will always be putting out heat, even if turn off. The thermal switch may also have burnt out. If this switch is open then the fan may be bad, causing the thermal switch to activate. The thermistor that senses oven temperature may also bed bad or have a poor connection somewhere.
F3 and F4 - These are oven temperature sensor codes.
- check the sensor by removing power to the range and then removing the sensor. Check that the sensor reads approximately 1100 Ohms at 72 degrees F. Then check the oven sensor lead to make sure that it is not shorted out. Then check the terminals to make sure that you are getting good contact. If everything checks out okay, then replace the control.
F5 – This is a relay safety circuit failure code
-check the lock circuit for problems. Then check the thermistor for high resistance. Press clear/off on the key pad and reprogram the control. If the code is still there then replace the control.
The F5 code can also result from a short loss of power. If you had a power flicker then reset the control.
FC – This shows a problem with the door lock circuit. Check all the wires and the switches. Check the operation of all the switches.
FD – This is a problem with the meat probe. Check the probe wiring and the receptacle where the probe plugs in at. Resistance on the probe should be 30 to 50K ohms at 72 degrees F.
FF – This is a problem with the door motor safety circuit. To fix this the control will need to be replaced.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jul 01, 2010 | Ovens
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery series oven
what is the model number is then we can get started then okay??
Sep 02, 2013 | Ovens
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
Was cleaning oven other night...wouldn't unlock when done...beeping f-3 f-2...trying to cook now in oven and it just keeps shutting off and beeping out of the blue f-3 f-2 again...cake in oven...HELP...
The only thing that I can suggest to you is to locate the breaker for the stove in the breaker box and turn off the power. Leave the power off for at least a minute. This will reset the oven to factory defaults.
Once you turn your breaker back on you should be able to open the oven.
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
