Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Deflection board where is the deflection board
  • 51 Answers
Your deflection power supply board is, looking from the back, on your left.
Posted on Jun 04, 2008
Sound but no picture
thats a vertical deflection issue replacing the deflection board should solve the issue you can get the replacement deflection board from www.tvrepairworld.com listed under the RCA circuit boards
Apr 01, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need deflection board for Hitachi 50UX26B
Please find the deflection board priced 28$ at the following link.
http://www.vancebaldwin.com/products/?JK03161
Many regards
EngineerGR
Apr 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Power light blinks 3 times but it does not come on
Thats caused by issues on the deflection board. It can be the power caps CP150, CP120 and CP114 or it could also be the Flyback and HOT tarnsistor or several other items all located on the deflection board. Often its easiest to just replace the deflection board on that model. You can get the deflection board from www.tvcircuitboards.com
Jul 21, 2011 | RCA HD52W59 HDTV Projection Television
My picture just faded out now the power light just blinks on and off but on picture or sound I turn it on and on/off lite blinks on and then off on then off again and stays off
The deflection board is the most likliest cause. The flyback and Hot plus the power caps all on the deflection board are famous for having issues. Often its best to replace the deflection board. Your model uses the PSB-260 deflection board which is available from www.tvrepairworld.com
Jul 11, 2011 | RCA R52WH73 Projection Television
Power indicator on front comes on briefly then goes off on then stays off
Replace the deflection board. The deflection board is famous for having various issues. You can get a replacement Deflection Board from www.tvrepairworld.com
Jul 03, 2011 | RCA HD52W59 HDTV Projection Television
I have a rca hd52w59 tv. turned it on this morning and it made a snowy noise in the back and shut off. what is the problem/ expensive to repair/
Most likely problem is the Flyback has shorted or CL031 has burned a hole through the deflection board both on the deflection board. Replaceing the deflection board is the best way to repair the issue. You can get replacement deflection boards for your model at www.tvrepairworld.com
Jun 14, 2011 | RCA HD52W59 HDTV Projection Television
My r61wh76 does not turn on. what could be the problem
With that model its common for the Deflection board to be the problem when it doesnt power up. It can be the Power caps, Flyback transformer or several other items all located on the deflection board, so its usually best to replace the deflection board . You can get the deflection board PSB-260 from www.tvrepairworld.com which comes with installation instructions.
Jun 13, 2011 | RCA R61WH76 61" HDTV
The tv wont turn on, the power button on the tv will light up then it will blink and shut off.
With that model its common for the Deflection board to be the problem when it doesnt power up. It can be the Power caps, Flyback transformer or several other items all located on the deflection board, so its usually best to replace the deflection board . You can get the deflection board from www.tvrepairworld.com which comes with installation instructions.
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture
Replace the deflection board. The ITC222A deflection Board PSB-260 is the correct deflection board for your model. You can get the replacement board from www.tvrepairworld.com the boards come with the CD with installation instructions.
Jul 08, 2010 | RCA R52WH73 Projection Television
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
