Question about Kitchen Ranges
INDESIT HI161IX - positioning above the cooker
My INDESIT HI161IX extractor hood has been delivered but without instructions. I need to know what's the minimal height above the oven it has to be positioned.
Please help - many thanks!
Nicola
  • Anonymous Mar 14, 2014
    instructions needed to install cooker hood
    Genius:
  • 1,224 Answers
If its hidden hood that pops up it just has to be flush with counter
this is so you have a clean flat service that make it look like you have extra room
if its a regular hood like old days height should be between 2 to 5 feet from stove to hood for quality air flow easy to install
Posted on Jun 01, 2008
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
Oven/Hood clearance
Minimum 30" from cooking surface is general guideline, check with your installation instructions, for liability and insurance purposes, if you do not, and something happens, you may not be covered. Follow specifications
Apr 01, 2009 | Belling XOU487 Electric Double Oven
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Jan 26, 2009 | CDA Kitchen Ranges
Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
Indesit cooker hood.
some have fuses, some dont. i know that if you dont have the vent hood hooked up correct the heat can melt the wires on the inside. so make sure the vent is hooked up right.
Mar 16, 2008 | Kitchen Ranges
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
253 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
