Question about Mitsubishi Televison & Video
I have replaced the lamp and it worked great the first night but when I tried to turn on the tv today it would not give me a pic. I did not touch the bulb when installing it now I have an amber light flashing on the front of the tv where the led for the lamp trouble is. the model # is WD-60735
  • 3 more comments
  • bonezcom69 Oct 12, 2010
    I have reinstalled the lamp and when I plug tv back in the amber light is still flashing
    it is the the led lamp on the front of the tv under where it says lamp
    Ok I got the amber light to go off but when I turn on tv I can hear the people talking but there is no pic then it will shut off in about a min. and there is no light comming off the lamp. I can hear the fan working is there a fuse or something that could be preventing power gatting to the lamp?
    I did not get it from mitsubiti I got it online from bulbsoutlet.com so it is prob an oem
    I have orderd a new bulb thanks fro your help
  • 10,594 Answers
Reinstall lamp and make sure lamp cover has fixed in its position securely after lamp installation.
Lamp cover is first thing that you remove from tv cabinet to replace lamp in tv.
Thanks.
Posted on Oct 12, 2010
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Oct 12, 2010
    read out label of that amber light to determine the possible cause of problem
    Blinking lamp light indicates that lamp cover is not installed properly, make sure it is fixed correctly because lamp cover has to press a safety micro switch, if that safety switch is open/ broken, tv wont power up.
    No fuse is there to prevent lamp to produce light.
    Is it original Mitsubishi lamp or some oem type bulb that replaced in old lamp box?
    Tell them that their bulb is not working and ask for replacement.
    Thanks and good luck
Tv won't stay on
sounds like lamp failure. the lamp is consumer replacable.
Aug 10, 2009 | Televison & Video
Same problem, my tv would power off every so often and then on
Unfortunately you have a defective ballast, that doesn't have enough voltage to keep on with your new bulb, it's better if you replace it so all this shananigans with the Tv can end, they're running around 60-70 dlls... you can go to discountdashmerchantdotcom to see if they have the one you need, the service is great, the only thing is that there's no warranty on the parts, but they do work, give it a try
Jul 01, 2009 | Hitachi 60V500 60" Rear Projection...
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
May 19, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Lamp is out? according to the red flashing light..Sony Wega 42"
I replecd my own lamp form my wega sony 58" rear projection lcd...it cost about 300 bux,,,just had to open the front lower panel iand replace the old lamp with new one ...it sound like thats whats wrong with your tv...mine got darker pic over time then jsut went out one dya and the red light would just flash when I tried to turn it on....try it....u can order lamp on the sony web site juust give them yoour model number and go from therr...
Feb 26, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Shutting off then on continuously, w/ green light on
I pulled the lamp, and blew the dust off of the top. TV is back to working great!
Oct 28, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
220 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
