Question about Gateway Computers & Internet
Gateway computer serial # 0028346288 - Ports on front of computer do not work. Also, printer works but computer show, "printer offline". Any suggestions as to this problem?
  • 1,679 Answers
You have not mentioned the Operating System on your PC and also the Printer which you are using.
First step is to Right click on the printer icon and click SET PRINTER ONLINE and Turn off the printer and turn on and try to print
If you are using Windows 7 Operating system,
Right click on the printer icon and Click on TROUBLESHOOT
Follow the instructions and this will resolve the issue.
Posted on Oct 12, 2010
Does the gateway sx2370 have special printer ports
All PCs have ports that can be used to operate printers and other peripheral devices. Most modern desktops have two ports that may be used for printers. A USB, or a serial printer port... it has lots of little holes in it on a socket. Depending on the type of printer you have, one of those will connect to your printer, if you have the cable. If you need to buy a serial cable count the number of holes and tell the place you need a serial printer cable with (number of holes) pins.
Jun 15, 2014 | Gateway Sx2370-Ur10p Desktop Black
Offline whats wrong
hi, check u r Computer's usb ports, usb cable . if will all r working ?
check printer's logic card or formatter card. may be capacitors r faulty.
Nov 06, 2013 | HP PSC 1510 All-In-One InkJet Printer
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
My Dell 1700n Printer keeps showing up as offline. I have a Dell Optiplex GX520 PC. My printer has been working fine, I moved the printer to a new PC temporarily and then moved it back to my PC and now...
hi
i suggest you reinstall the drivers on the computer(s) which will use the Dell 1700n printer.
let me know if this helps
if you need the drivers go to this link all you have to do is select the operating system (go to My Computer, right click and properties, will give you the OS)
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
Nov 03, 2010 | Dell 1700n Laser Printer
My PC shows that my printer is offline when it is not, and the option to "scan to image" is no longer on the scan menu on the device.
This means that the computer cannot communicate with the printer. Try a new data cable and plugging the unit into a different port (USB). Make sure the port works with a known working device.
USB ports can be disabled for security and power savings. Legacy ports (parallel or serial) are not always enabled on the few boards that have them.
If you use a print server or USB hub, try a direct connection.
I hope this helps.
May 01, 2010 | Computers & Internet
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Printer is offline message appears (printer is networked)
change your usb cable.or try to reinstall the driver again
Jan 06, 2010 | HP LaserJet 1300 Printer
USB ports no longer work
you need to check your device manager and make sure the device manager is reading the USB ports, if not, you will need top get a USB driver or go to ADD NEW HARDWARE, and search through there until you find universal serial hub or bus then click ADD
May 05, 2009 | Gateway 6510GZ Notebook
Gateway gt4010 usb ports are all failing.
It's your hard drive going bad! I had the same problem in my company. Could not figure it out but when i flopped the hard drives they started working agian.
Mar 26, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Printer shows offline
your next plan of action should be to let the printer reset its self. Unplug the printer for a few minutes then plug it back in. Turn printer on and try to print something. If this does not work then what i would do is use add remove programs and remove the software and drivers for the printer and re install them again. Read and use the manufactures recomended way of installing your new printer. Start off with printer unplugged and usb unplugged then begin as if you bought it brand new. I cant stress enough how important following the manufactures instructions are.
Feb 19, 2007 | Lexmark X1150 All-In-One InkJet Printer
Computers & Internet Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
