Question about Saeco Titan Coffee Grinder - Gray
Why the grinder stopped working automatically?
    Genius:
  • 1,478 Answers
heck to see if the grinder is plugged in. After making sure it is plugged in, press the on switch in the grinder's center for the wheel to start spinning.
Check the extension cord for damage if you are using an extension cord. The cord may be so damaged that it no longer works.
Check the grinder's power cord for any problems, such as exposed wiring. If there are any wires visible or the cord is severely bent, electricity may not flow through the cord and into the grinder. If there are any problems, the broken power cord will have to be replaced with a new one.
Take care.
Posted on Oct 12, 2010
Door from grinder will not let coffee into brew unit
From the description I understand that the flap at the outlet from grinder is not easy to open and let coffee grounds out from the grind chamber.
Firstly this is a mechanical obstruction and not related to any electrical or electronic control.
This happens frequently in the Ceramic burr grinders due to the following reasons:
1- The beans used are dark roast oily. Such beans are not good for use i any fully automatic model. This should be stopped immediately.
2- The grind fineness may be set at fine powdery level. This is done because there is wrong assumption thata fine grind makes stronger espresso. That is not applicable in fully automatic machines. The extraction of espresso in fully automatic machine is with pre infusion (also called pre brew soaking) and uses a back pressure valve for 9 bar extraction pressure. For this reason
the coffee grounds should not be finer than table salt grain. If coffee fineness is set at powdery fine, then the setting should be changed to coarser setting.
3- Grinder may not have been cleaned for an extended period. If so clean the grinder. Use brush or scrape solid deposits in corners and crevices to clean.
Finally as a part of cleaning, use a rag wrapped on finger or screw driver to wipe the invisible oil deposits on the grinder parts between the burr and the outlet.
Check the flap in the coffee outlet is hinged correctly and moves freely front and back to make sure that it is not blocking outlet for ground coffee.
Jun 25, 2015 | Gaggia Titanium Espresso Machine
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Oct 18, 2014 | Coffee Makers & Espresso Machines
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
How do i adjust the blades/grinder on my Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 876
I don't see a model 876, but there is an 875s. Here is the wesite for frindmaster and the 800 number or user manual for help. Coffee Grinders
May 15, 2014 | CoffeeForLess.com Grindmaster Automatic...
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
It wont stop beeping
Is it still beeping? ;) It will beep if you have the automatic brewing programed and the grinder and it's lid are not in place.Once you have put the grinder back in place, push the small white button down that is on the grinder lid. The beeping will stop. Don't press the program button again or it will start beeping again...but if you do, just push that white button again.
Aug 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Espresso coffee grinder stopped working
many grinders have resetable termic fuse, some of them require manual reset, so you should search for termic fuse attached to body of motor(open the grinder from below) usualy they are round black termofuses with red reset button.
usualy this happenes when we have loud music and we dont hear that grinder is on and he works long time.
Mar 28, 2009 | Isomac Gran Maccinino Espresso Coffee...
Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Jan 28, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
Nov 09, 2007 | Cuisinart Supreme Grind CCM-16PC Grinder
Saeco Titan Coffee Grinder - Gray Logo
145 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
