Question about Dishwashers
Danby dishwasher ddw 2406 bls-1 i am getting an error code 0004 and the machine will not run
  • sruyter Oct 13, 2010
    the error code is 004 and the only spot there seems to be any water is in the reservoir where the salt is added . One other odd thing is the machine will stay on for sometime even when you open the dishwasher door. I can hear the pump running to empty the dishwasher and a small amount of water seems to be going through the drain pipe each time I cycle the machine on and off.
  • sruyter Oct 14, 2010
    This worked like a charm
    thanks a bunch
    Steve Ruyter
  • 10,515 Answers
Is it 0004 or 004?
I am aware of the error 004 which states :-
Error code 004 is caused by water being present in the bottom tray of the machine. There is not supposed to be any water there but if there is any the float switch is triggered. Get rid of the water source and the problem is fixed. On my machine the leak was in the feed pipe to the upper dish tray. I replaced the feed pipe and problem solved. Water could be leaking somewhere else however so you will have to find and fix the leak.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 12, 2010
  • taran_2005
    taran_2005 Oct 13, 2010
    Thanks for your response!!
    Pull dishwasher from under the cabinet and look at right side of
    machine, get a flash light pull the insulation away from machine stick
    the light in look for the white little resovoir and the styrofoam float
    switch.Siphon the 1/2 cup collection this allows the float in the attached cup to drop kicking the sensor out.
    Hope i helped you.
Electrolux dishwasher giving error code 1?
Good Morning Brian,
I understand that you are receiving an error code 1 on your Electrolux dishwasher, model# EWDW6505GS. Error 1 is stating that water has been detected underneath the tub. Check underneath your dishwasher by taking off the kick plate below the door. If you do not notice any water underneath the tub or any types of leaking, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker for 20-30 minutes. When the time has passed, restore power, and run any cycle. If you are still receiving error code 1, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Electrolux EWDW6505GS Fully Integrated...
Defy DDW 169 manual
My Defy DDW 169 Dishwasher won't go beyone draining on starting a wash cycle. What is the problem with the machine?
Dec 18, 2013 | Washing Machines
Error code #4 on ddw1899wp danby dishwasher
see this possibles causes:
you must read your instruction manual and go to the section troubleshooting for fix it the error codes. If you do not have go www.fitness.manualsonline.com or www. retrevo.com
God bless you
May 25, 2012 | Danby Dishwashers
Dishwasher: danby ddw1806bsl. Getting error code E4 "too much inlet water". How to fix that?
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
Sep 22, 2010 | Danby DDW1806BSL Stainless Steel Built-in...
Ddw counter top
Thanks for your reply.
I finally found the instruction booklet and used the method
of adding Vinegar and problem was solved.
Thanks
Feb 28, 2008 | Danby Dishwashers
Danby dishwasher
Call Marcone Supplies, Tampa Florida. (they are Danbys Supplier for parts.) DO NOT WASTE YOUR TYIME CALLING DANBY. They are not helpful. Danby 18" Dishwasher. Model # DDW 180 2W Parts 800-482-6022. Marcone:Very helpful. My door is open; thank goodness; it just will not stay closed. Latch broken on door. I have to order the "whole handle assembly" (all one piece which includes the door handle latch too.) $4.16 shipping from PA. I am in Calif. Total $12.53. 2 screws. Easy. I can do it, I know I can. (Signed, a woman in LA!)
Jan 22, 2008 | Danby 17 in. DDW1802W Designer Series...
Danby ddw2406
Simple solution. DO NOT spend the money on a tech coming to the house.
This error code comes from getting too much water in your machine, either from a dish filled with water emptying, or perhaps a clog from the sink that prevents your machine from draining. It is meant to prevent overflows from too much water being in the tub. It is a simple fix though!
First of all you should at least shut the power off on your machine. For the effort of a couple of more steps, it wouldn't hurt to shut the breaker off at the fuse panel. You will have to unscrew the undercounter tabs that mount the dishwasher to the countertop. They are located just under the counter sticking out from the top of the dishwasher when the door is open. Then proceed to pull out the dishwasher from under the counter. You will only have to pull it out about half way and you will find the overflow valve. It is located on the right side of the dishwasher just under the insulation and level with the lower hinge on the door. (Right side when you are looking at the machine.)
There are two overflow valves. One looks like a small cup, the other looks like a cylinder with a float in it like your toilet. Both of them have black rubber covers near the bottom. Take these covers off and about a quarter cup of water will flow out of these overflow basins. Allow them to completely empty, then replace the rubber drain covers and then replace the unit under the counter.
Once you turn the power on, the error code should be cleared and you are ready to use the dishwasher again.
Jun 03, 2007 | Danby DDW2406 Stainless Steel Built-in...
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
181 people viewed this question
Top Dishwashers Experts
