Question about GE JBP24 QuickClean Electric Kitchen Range
Where do you buy replacement insulation ?
We had a problem with mice and the have destroyed the insulation around the oven, and I'm not sure where to or what type to buy to replace it?
Any help is greatly apprenticed.
  • macent Nov 11, 2008
    we have the same problem but our oven has self clean! Can it handle that high self clean temps?
    Thanks
  • tinatoes Jan 11, 2009
    my frog Bob likes to eat flies and bunnies,but Jimmy my dead bird who died 5 years ago,ate ALL of my insulation and pet bunnies 2 years ago.
  • 868 Answers
Just use the standard fiberglass insulation (home a/c filters are pennys for the amount you need)
Posted on Jun 01, 2008
Replace insulation in Kenmore stove
These are usually easy enough to take apart if you have have a well lit large room to work in, and take photos of what you remove as you go along.
First get it in a space where you can walk around it. Remove all SMALL screws from the back and wiggle panels as you go to see where they loosen and are still fixed by other screws. Take a sequence of digital camera pics as you go. You are trying to replace the insulation in the back and sides so you only need to remove the outer panels, not take the whole thing apart.
Dec 20, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Insulation gone in Jandy Lite 2
need new heater that one is unsafe
Jun 02, 2013 | Jandy Pool & Spa
I have a small, 4-burner gas stove; no wondow in the oven door. I think my stove had a mouse infestation. I think the insulation above the oven has mouse urine in it; I can smell it, although there is no...
It is common for mice to get into the oven box insulation and nest. I had this problem before and its not likely you'll be able to get rid of the odor without replacing the insulation. Another issue is any fecal matter the mice leave behind. This can become a health hazard (expecially in an appliance that you use to prepare food). I would recommend replacing the insulation. If the model oven is correct, the insulation can be purchased for around $20 at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number will depend upon your COMPLETE model number (located on a nameplate around the oven door opening, or lower drawer opening (if equipped). On some models, the model number will appear on the back of the operator console. The first three sites on the list include exploded view parts illustrations to assist you with locating and properly indentifying any parts you may need. The insulation for the Magic Chef 31000 series is listed under the "Body" parts list.
To replace the insulation on MOST ranges, all you should have to do is lift the range top to access the oven box. The top on most ranges can be lifted by removing a series of screws that are usually holding it secure under the bottom of the front edge. You will need to open the oven door to see them. CAUTION: Do not lean on the oven door as this may cause damage to the door hinges and springs.
On the Magic Chef 31000 series, it appears that you will need to remove the burner control knobs, followed by screws holding the burner control control panel in place. You should also remove all the orifice covers and burner grates from the top of the range. Once the burner control is removed, remove the top panel, followed by the burner box top panel. The insulation will be wrapped around the oven box. It should just lift out. Depending on the potential infestation, you may want to wear a dust mask and use a vaccum to **** up any loose debris. CAUTION: Turn off the gas supply BEFORE attempting any repairs - if this is a gas range.
If you have questions, please post back and let me know. I hope this helps you.
Apr 28, 2011 | Magic Chef 31000 Gas Kitchen Range
Where can i buy keyboard surround for advent k200
Try Shopping for it at this following website:
http://www.keyboardweb.co.uk/companies/Advent.htm
or Google:
"Acer Advent k200 Replacement Keyboard"
That should do it for you.
make sure you use a walkthrough/diagram/faq to replace it or risk shorting out/ destroying the hardware.
Nov 30, 2009 | Acer Computers & Internet
Gas cooker insulation
just buy some fire proof insulation from any hardware store
Jul 23, 2009 | Tappan TGF320 Gas Kitchen Range
Insulation around RV oven
Use a "high heat" fiberglass composite insulation. It comes in sheets and rolls.
Apr 25, 2009 | Kitchen Ranges
Rat Nest in oven insulation
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Dec 19, 2008 | Tappan TGF320 Gas Kitchen Range
GE JBP24 QuickClean Electric Kitchen Range Logo
742 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
