Question about RCA TruFlat 27F520T 27" TV
Tv turns itself on and off by itsellf - RCA TruFlat 27F520T 27" TV
  • 3 Answers
The power supply components (triacs, capacitors, etc.) are failing.
Replace the TV or get it repaired.
Posted on Oct 13, 2010
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
How to adjust brake light switch on 2004 - 2007 s-type 2.7d
remove switch by twisting it then resets itsellf when you refit
Apr 14, 2013 | Jaguar S-Type Cars & Trucks
Turning my headlights on blows the fuses to running lights and dashlights
headlight switch is bad, change the headlight switch itsellf will short out, therefore blowing your fuse. turn signals and break lights are on a different relay, therefore they will still work
Sep 07, 2012 | Subaru Legacy Cars & Trucks
Turns off by itself after i've turned it on
I have this same TV and had a similar problem. This may or may not be the same case with yours. The button panel on the front of your TV may be having connection problems. Mine would come on and off by itself. I took the front panel off and cleaned the connection on the button board with a q-tip and a little dab of alcohol. This cleared up the problem of it turning itself on and off.
Mar 20, 2009 | RCA P46924 46" Rear Projection Television
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
My TV turns itself off and on by itself.
You have a timer that has been accidently set by someone by the remote control.
If you have an instruction amnual for the tv, it will tell you how to turn off the tv's timer.
Feb 13, 2008 | RCA P52930BL 52" Rear Projection...
Heat Not Working
Pls follow the step
1) Check your connector wire to the termostat (possible may be loose).
2) Set your thermostat up to 29C and set to heat control.
3) Check the connector wire to reversing vale (possible may be loose).
If they not solve the problem your Control Board have a problem,pls go to the nearest service center for repair.
Thanks & best regards
Edgz
Jan 18, 2008 | Fedders D Chassis AED24E7E Air Conditioner
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
RCA TruFlat  27F520T 27" TV Logo
164 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
