Question about Roper RGS7646KQ Gas Dryer
No power to ingiter element - Roper RGS7646KQ Gas Dryer
    President:
  • 1,430 Answers
You will need to check the safety fuses. Here is a video at this will walk you thru troubleshooting a gas dryer.
Posted on Oct 12, 2010
2005 Honda element ingition switch do you have to take strewing wheel off
No, you don't have to take the wheel off. Just have to take the cover off between the wheel and the dash. Once that's off, then you will have access to the ignition. The only thing is, when you get your new ignition in, you will have to take it to a Honda dealer and have the ignition and key coded together. It will save you some money to put it in yourself, but you will have to tow it wherever the closest dealer is for you.
Sep 13, 2014 | 2005 Honda Element
Honda keyfob reset
Ingition switch on -> press lock
Ingition switch off -> on -> press lock
As fast as u can on the fifth cycle the car will lock
program is complete
Feb 15, 2014 | Alarm Remote Casecover Accord Odyssey 02...
Smc Ram new ignition
the majority of wires are constant power to lights ingition ect.. their is only one temp hot that will come from youer ingition coil switch . you have three poles on switch to conect too .positive negitive and temp positive . all positives are to positive on switch except one if two from coil . Next conect all your neg wires to neg poke
Jun 04, 2013 | ATVs
Lost all power an can not remove key
Apply power to battery to remove key. It's happened to me many times. Good Luck
Nov 20, 2012 | 1997 Chevrolet S-10 Pickup
The dryer does not dry. No heat. I took off the bottom plate and turned on the dry. An electrical element turned a bright orange for a few seconds and then darkened. No gas went on.
Because you have a gas dryer, your problem is probably caused by the ingition panel, the electrical element that you saw turn a bright orange. Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat.his is what you described when you said the element only lit for a few seconds. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 24, 2011 | Dryers
Igniter keeps firing without being turned on.
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter.
Jan 31, 2011 | Thermador 37 in. SGSX365 Gas Cooktop
GAS hob keeps sparking when pluged in
Jan 18, 2011 | Cooktops
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Starter stays enegaged on 1990 mustang gt
sounds like solenoid is shorted to ground internally
Dec 02, 2008 | 1990 Ford Mustang
Renault laguna 02 1.6 16v loss of power
I have we a 1988 Renault 2.2 engine that keeeps loosing power. Replaced ignition module & tempature sensor, crank sensor. Please help!
Oct 07, 2008 | 2001 Renault Sportwagon
Roper RGS7646KQ Gas Dryer Logo
43 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
