Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
I have model # p-m267a-nc-c it comes on I git error cfh then after a while i git hl2 and it wont heat after that. HELP Please TKS
  • 44 Answers
"CFH" is Call for heat. That means your heater is trying to fire (not an error code). "HL2" is an error code which stands for "High limit #2". This error means the water in the heat exchanger is too hot,and the heater shuts itself down to prevent damage. Most common causes are poor water flow .Make sure the correct pump is running,and you have at least 10psi on the filter gauge. also be sure that the bypass valve is at least 1/2 way closed.The Bypass valve is located on the return line after the filter just passed the first tee.
Posted on Oct 13, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
Error code cfh
cfh is not an error code. it stands for "call for heat". back wash the pool filter. check continuity of pressure switch to ensure it is closing at proper pressure. jump pressure switch and if heater fires, there lies your problem
May 03, 2013 | Raypak Pool & Spa
Error code h4-01 ar-c260m?
Your fuser is not warming up in time. 01 is for HL2 the lower heat lamp. Cancel with Sim code 14/execute/yes and let the machine reboot. If the code comes back you must replace the lamp.
Jan 29, 2011 | Sharp AR-C260M All-In-One Printer
What is CFH
CFH stands for "Call For Heat"
CFH means "Call for heat" and SPK means "Spark". They are status codes, not fault codes.
It basically means that the heater is turning on the heat mode and spark should appear shortly after the CFH code appears. At this point the heater should be igniting and the heater heating up.
If you are having a fault issue with the heater, please let us know if there is anything else that we can do for you!
Dec 16, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Mar 16, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Raypak pool heater, error HL2
It is probably the pressure switch. Remove the hose from the inducer and **** in and then blow lightly several times. It is probably stuck in the either the open or closed position. If this isn't the problem, check your manual reset limit switchs to make sure they haven't tripped. Also, make sure your are getting power to the ignighter as well.
Mar 16, 2009 | Ruud Central System Air Conditioner
Half Life 2 Episode 1
Have you tried reinstalling HL2? What is your system specification..
Oct 20, 2007 | Sapphire RADEON X300SE, (128 MB) Graphic...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
543 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
