Question about Nakajima Office Equipment & Supplies
How do I put the correction ribbon in correctly? Do you have a help page for that?
  • Nakajima Master
  • 3,594 Answers
Contact Nakajima @ 800-809-7138 they are very helpful.
DickyO
Posted on Oct 18, 2010
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
Changing correction tape in model SL 105 I am attempting to put in a new correction tape in my Model SL 105. It appears to be moving, but I am getting no correction.
If the correction tape is moving and lifting there is a good possibility that the ribbon or correction tape are old and have changed composition or you have a non correctable ribbon.
DickyO
Sep 21, 2011 | Smith Corona Office Equipment & Supplies
I have a gx6750 correcting typewriter. The problem is, the correcting part of it does not work. I am wondering if the correctable ribbon indicates "correctable" on the cartridge or not. I am...
A correctable ribbon should be correctable. Is the ribbon being lifted up high enough to correct?
Is there any letters on the correction ribbon and is the ribbon installed correctly? Old ribbons lose their tackiness over time, try advancing the ribbon by hand to get to fresher ribbon.
Jul 08, 2011 | Brother Office Equipment & Supplies
Correctable Ribbon not working. Even tried putting new one in
If the correction is lifting and being struck by the hammer the correction tape may be on wrong, the dull side must face the ribbon. The other easy possibility is that the ribbon is very old or non correctable. It should have a yellow or orange knob not red or blue.
DickyO
Mar 26, 2011 | Brother SX-4000 Typewriter
The correction tap will not pick up all ink?
When the correction dosen't work the ribbon and or the correction tape are old. Put a fresh ribbon and correction tape on. Not one that has been sitting on the shelf for years.
DickyO
Nov 11, 2010 | Brother ML-100 Typewriter
I cannot replace the ribbon correctly. I have
You may download a copy of the manual here. The ink ribbon replacement instructions are on the first page.
Sep 30, 2009 | Sharp EL-1197P Calculator
Print is very light and I put in a new ribbon. This printer is hooked to a parallel port on an AVAYA phone system terminal. I don't believe there is an option to download drivers. Not sure why the new...
Hi
Check if the ribbon is seating correctly, the Avaya PBX does not have a driver for this that is correct also some printers have a "draft"setting make sure this is off as the printer will only go once over the print in draft
Sep 29, 2009 | Panasonic KX-P2130 24-Pin Impact Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Correction ribbon
You must make sure the black ribbon is a "correctable" ribbon and not a "multi strike" ribbon. You can usually tell by the color of the dial on the ribbon. A correctable ribbon is either yellow or orange. If it sis any other color then is will not correct. Hope this helps.
Oct 12, 2007 | Brother SX-4000 Typewriter
27 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Adorjani Laszlo
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
