Question about Samsung HCL4715W 47" Rear Projection Television
Picture Moved Up
I have never had ANY problems since 2001. Last year, out of the blue, when watching a tv program,the picture moved up, 1-1/2 in. from the bottom of the screen cutting off the top of the image. However, if I watch a DVD or VCR movies the picture is perfectly centered, this only occurs when watching TV programs.
Any suggestions/solutions will be greatly appreciated!!!!
  • LV117 Jun 01, 2008
    Unfortunately, this is not an issue of setting up the picture orientation. We've tried this.
    Thanks for trying!
  • 1,031 Answers
What type of device ar u using?check the access panel to get to
the screen control adjust then adjust focus..........
Posted on Jun 01, 2008
  • Starnley Johnwells
    Starnley Johnwells Jun 01, 2008
    Adjusting your picture orientation on your HiDef television is a sort of complicated affair. Understanding dimension formats will help you to set the best screen setting for your television. All the old models of televisions that had a CRT (cathode ray tube) had a generally square shape to them, as opposed to rectangular. These traditional screen dimensions were referred as a 4:3 (ratio) dimension. Newer flat panel televisions and computer monitors are referred to as 16:9 (ratio) dimension because they have a wider width.
    DVD Wide Display
    Set the size of the on-screen image for DVDs. This setting is active only when the TV type is set to [4:3] under (Settings) > (Display Settings) > [Video Output Settings].
    check the following display setting on your panel box
    Pan and
    Scan
    Set to display the image to fill the TV screen by cutting off portions at the top and bottom or left and right sides of the image.
    Letterbox
    Set to display the image in its original proportions with black margins at the top and bottom of the image.
    Off
    Set to disable upscaled output.
    Double Scale*
    Set to upscale and display with double horizontal and vertical dimensions without changing the proportions.
    Normal
    Set to upscale and display at a size that matches the screen size.
    Full Screen
    Set to upscale and display at full screen by changing proportions and stretching the image
    * If you change your picture orientation on your television to letterbox, you will be able to see the full width of the picture, and then you can "autosize" stretch the vertical dimension to the full height of the screen. This results in a picture that uses all of your screens real estate, with the least amount of distortion.
    President:
  • 2,712 Answers
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Jun 01, 2008
    It could also be a software issue with the TV and will need to be reset , or there could be a problem with the DG board. It is best to get a TV repair gguy to take a look at this for you.
  • Swilin Sampson
    Or it could be matter of simply replacing the EEPROM chip. You could also try a reset..Hold down the power button and OK button for about 3 seconds.
    If that fails, try a hard reset: Unplug the TV from AC source and remove all cabling. Wait about 30 minutes and replug everything and see if that helps..
  • Swilin Sampson
    Swilin Sampson Jun 02, 2008
    Most likely you need to upgrade the firmaware via the EEPROM chip. This can only be done by a technician..
Green tint to picture.
Are you using the componant connection on your tv? If so, check the red, blue and green cable connections on both ends. They carry your
picture info to the tv. The audio is carried by a red and white cable. There should be 5 cables for a componant connection. 2 reds, 1 white, 1 blue and 1 green. I hope I have guessed your problem correctly and this helps you.
Apr 07, 2010 | Sansui HDLCD-1900 19 in. LCD Television
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
ILO TV
push the "Pic Size" button and make sure it is not on Panoramic, that setting stretches and warps the right and left side of the picture
Oct 22, 2008 | iLO 3200 32 in. LCD Television
Sony with blue screen
make sure you are on tv slection and not video1 ,aux . pull up menu go to setup look for cable/air make sure you are in tv mode not video aux.if this does not fix it then you may have bad tuner.
Jan 13, 2008 | Sony KP-43HT20 43" Rear Projection...
Mitsubishi WS-65908 picture problem
since this happened after you moved i would look for loose connections on the convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Mitsubushi rear projection 50 inch bought in 2001
I would say the last repair knocked a solder joint loose in the vertical circuit. This is a common problem when moving rear projection circuits boards or the whole tv. I have had customers move their TV from one room to another for what ever reason and when they moved it back it wouldn't work right. These sets get real hot and destroys the solder joints. Is it worth fixing??? Only you and your wallet can decide that and of course the local service man and what he charges.
Dec 15, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Rca 27v41st blue at top of screen, picture moved down
No, you have a vertical collapse problem only correctiable by changing internal components. Sorry :-(
Sep 14, 2007 | RCA 27V520T 27" TV
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
No Picture
As long as you can hook that same cable up to a different TV and get a good picture, you must have somehow damaged the tuner on the APEX - unless the set was mishandled while moving. Those cheaper brands won't take much punishment.
Jan 20, 2007 | Apex Digital AT2008S 20" TV
Samsung HCL4715W 47" Rear Projection Television Logo
88 people viewed this question
Henry  Thomas
Henry Thomas
