Question about Star Logic 17" LCD Monitor
Hello - I have a Starlogic hd17a monitor and can't seem to find the specific power supply for it online. Any suggestions? Links would be great! 12v DC, 3A
5 Suggested Answers
SOURCE: Changing Resolution
the color is off and the brightness will not adjust corretly...
Posted on Oct 13, 2008
  • 298 Answers
SOURCE: What power supply required for my ECS Elite
Normally (90%) it is center positive. The larger outside is effectively 'Ground' and not only connects the inside socket securely to the motherboard, but also provides massive support to keep it aligned and attached by connecting to the most massive copper parts of the PC Mainboard inside. In most cases (pun intended) there is a diagram of a C with a o inside somewhere near to the connector on the PC which tells you which is definitely which. AC doesn't matter, so if its 12V 3 A ACV it makes no difference which is which... and in those same 90% of cases, there is a Diode on the Positive side which only allows POSITIVE (+) volts to flow in IF the other side is more NEGATIVE (-) so no worries... it will not smoke ;-)
Hope that helps
Posted on Apr 08, 2009
PC Rescue
  • 7 Answers
SOURCE: My Starlogic monitor fails to power up. We had a
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Posted on Jun 16, 2010
  • 196 Answers
SOURCE: StarLogic monitor HD20W driver needed
go to www.starlogic.com
Posted on Jul 26, 2010
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Jun 16, 2010 | Star Logic 17" LCD Monitor
When i first turn my monitor on it works great for a few seconds. If i turn it off and back on it works for a few seconds again then blacks out. If i un plug the power source instead of the on/off button...
larry946, Sorry guy... Your power supply is not OK!!! I'm talking about the one inside the lcd monitor!! It seems as if it is detecting a "FAULT CONDITION" and then proceeds to go into "partial" or "full" shutdown mode, trying to avert a catastrophic, nonrecoverable failure. e.g. sparks smoke, fire. Partial = black screen with data still visible when flashlight held 1 inch from screen. Full = black and blank screen. What will you do now? The only good thing you told me was "WORKS GREAT FOR A FEW SECONDS" !!! That makes it a good CANDIDATE for a low cost repair if you do a DIY fix. If StarLogic warranty has expired and they don't have a "cash+old unit" swapout program for a refurbed unit, you will need to explore all your other options. Read thru my FIXYA profile and you will soon discover that your StarLogic unit is no different than any other CCFL backlit LCD monitor. Follow the links to the other websites you find in the profile to help you make the decision to DIY or contract out (more$$) the needed repair to your unit. READING is free!!! So do a lot of reading, and you will be better informed and not subject to getting ripped-off for $90 when it should have been only $25 to $45!!! Good luck with the repair! 12fixlouie or old aka louie12fix
Jan 06, 2010 | Star Logic Monitor 11009515
How to covert Starlogic M17ANA into tv screen.
yes a dvi to VGA converter is available they are available online and over the counter at an electronics or computer store
Feb 05, 2009 | Star Logic 17" LCD Monitor
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Sceptre LCD Monitor
I did not have a power adapter for my lcd monitor but after 2 weeks of searching stores, internet and universal adapters I found the power adapter for my specific monitor on ebay. If that doesn't work I would suggest a universal power adapter.
May 28, 2008 | Computers & Internet
X2gen MW19R user manual
Maybe they put more volts on it, because of the cable length. About putting the manual on Fixya. I do not know how you would do that. I know that you can have a little more volts and be okay but not enough is bad. Are you sure it is the correct cord?
May 22, 2008 | Computers & Internet
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Starlogic monitor
I been working on lcds for some time and what I find is caps in power supply dry out over time. If you can open case and see if cap pop out at the top of it. thats your problem...cybrg0000
Oct 21, 2007 | CTX S762A 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
44 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
