Question about Singer Inspiration 4210 Mechanical Sewing Machine
The top needle will not pick up the thread from the bobbin
    Genius:
  • 1,478 Answers
There are several reasons why this would happen. In order of importance,
You are not holding the thread tails when starting a seam - The needle is not properly installed in the needlebar - The machine is not threaded properly - The machine needs adjustment or repair Check that your needle is not installed backwards. On my Singer the full-length groove (not the short partial groove) has to face you.
Check needle is not bent.
Take care.
Posted on Oct 12, 2010
Bobbin doesn't move so that needle can pull thread up from bobbin
If the tail is long enough on the bobbin thread and the top thread does not pick it up, try a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread. If a new needle doesn't help, then your machine is probably out of time. Search for sewing machine timing or take it for service.
Mar 18, 2017 | Sewing Machines
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Feb 10, 2016 | Sewing Machines
Neddle will not pick up bobbin thread
Check the needle to see if it's damaged
check the needle to see if it's in backwards
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 28, 2010 | White Sewing 1521
My machine will not sew. it isn't picking up the bobbin thread
Lower the needle in the bobbin area & see if the bobbin thread will pick Up that way
Sep 26, 2010 | Singer 7430.CL Computerized Sewing Machine
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
My machine is not picking up the stitches. I have rethreaded, checked needle and tension.
try these suggestions
Not picking up thread can be several issues
1.bobbin is miss wound
2. bobbin case isn't snapped in properly
3. you're using the wrong type bobbin
4. needle is bent or burred
5. check bobbin area for lint & loose threads
6. little oil--check operation manual for this
7.machine is out of time --done by service tech
8.check automatic thread cutter to see if it’s bent
but most of the time the issue is once again mis-threading or the thread coming off take up lever
sewing machine needles put in incorrectly
Check & make sure needle is in the needle holder correctly.
Check your manual for threading diagram
check bobbin area including case for lint & loose threads
Take the needle plate off & clean under neath it ( if your machine has screws that hold the needle plate on be careful NOT TO DAMAGE THE SCREWS) because a damaged screw that has a burr on it can pull fabric
Each time you start to sew
1.make sure there’s 2 to 3 inches of top thread when you put the needle down for the bobbin thread
2.make sure there is a 2 to 3 inch of bobbin thread so the top thread can pick it up
3.Pull the tail of the top and bobbin thread behind the presser foot
hope these help--please rate this with the thumbs in the upper right hand corner-thank you
Aug 06, 2010 | Sewing Machines
Top thread doesn't pick up the bobbin thread (Toyota sewing m.)
Hi! This may sound silly, but if you changed your needle and put it in backwards (which is easy to do), the top thread won't pick up the bottom thread. Take your needle out and check the flat side of the needle shank--which way is it facing? With a lot of the newer machines, the flat side goes to the back, but check your manual to make sure.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Feb 12, 2010 | Sewing Machines
How do you get the needle to go down to pick up the bobbin?
Thread top needle, pull and hold thread in back, make sure your bobbin is threaded and in correctly, turn the wheel toward you it will pick up the bobbin thread and bring it up top. Then seperate your threads up on top. Is that what you were asking?
Sep 22, 2009 | Sewing Machines
Needle will not pick up thread from bobbin
If you have correctly inserted the bobbin, try mmoving the top thread by hand gently up and down into the bobbin area. I let my top needle pick up the bobbin thread this way before using the pedal. I pull a long strand of bobbin thread out before pushing the pedal too.
Sep 21, 2009 | Singer Sewing Machines
Singer Inspiration 4210 Mechanical Sewing Machine Logo
67 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
