Question about Maytag MSD2650K
Water not getting to water dispenser or ice maker - lines are clear.
  • Maytag Master
  • 3,289 Answers
Do you hear a clicking sound when attempting to dispense water? A click is usually heard when either of the water supply solenoid valves (one for water & one for ice) opens and closes when dispensing water, or when refilling the ice cube tray right after the ice maker dumps the ice cubes.
If you don't hear the clicking sound, there is probably an electrical problem. Given that BOTH water and ice no longer work, I doubt it both the water and ice maker water solenoid valves failed at the same time. It is probably going to require some digging to solve it.
If you do hear a clicking sound, check the shut off at the supply source. The "tap" type valves that puncture a sink's cold water supply line can become clogged by mineral deposits over time. Make sure that the fridge isn't resting on a supply line, effectively crushing it shut or closed - likewise, the line may have become kinked when the fridge was pushed back into position. You should try to dispense water while the fridge is out from the wall to see if it is a kinked line. Check the entire exposed length of the line for evidence of crushing, too. If the line is routed in cabinets, etc. you should try to inspect the line to make sure nothing fell out of a drawer - and crushed / kinked the line. Replace any damaged water line found. You could shut the water off, and remove the line from the fridge - then have someone turn the water on while you hold the line to fill a container. If it flows - the problem lies in the fridge. If not - it could be a clogged inline filter or bad valve.
There are a bunch of things to check that should be pretty easy to start. Hopefully, you needn't go any further. Good luck!
Posted on Oct 12, 2010
Ice maker is not getting any water but it is dispensing water
I believe that it might just be the filter. I know it sounds crazy but bits true.
Sep 11, 2014 | Whirlpool Refrigerators
My ice maker quit making ice the other day. I finally got under there and checked everything out and it all seems ok. The problem looks like there is no water coming in from the supply line. Why would...
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
When your ice maker dumps and refills with water it will come out the water dispenser with the wires swapped. If it doesn't then I would have to blame it on the solenoid.
If the lines are the same size you can also swap them around to do this check.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it's getting power it should click when you try it and water come out.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 18, 2011 | GE Profile Stainless Bottom-Freezer...
Water is not getting to the icemaker. however, it is dispensing at the glass tap
Water inlet Valve
Dec 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
Ice maker is not getting water, water dispenser is. there is notheing frozen but the line leading to the ice maker doesn't have any water in it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 30, 2009 | Frigidaire FRS26R4A Side by Side...
How to fix automatic ice maker thats not getting
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
Sep 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No ice
Sep 04, 2009 | Whirlpool GD5SHAX Side by Side...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Maytag MSD2650K Logo
198 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
