Question about Video Game Consoles & Games
I just added the aerobic step to my balance board now my weight is all wrong when i check it
  • 104 Answers
Is your board on carpet? cause scales dont dork on carpet
Posted on Oct 16, 2010
I recently purchased the 10 min solution game. I can calibrate the wii balance board just fine, and it works perfectly with any step aerobics that I do in the 10 min solution, however, if it switches to...
Here's what I think I figured out. The balance board powers off for the cardio boxing because it is not needed. The movements are measured by the hand remote and nunchuck not the balance board. The "bob" is still tricky to time right; great workout trying (sure hope I can walk tomorrow)! The trick is to move when the indicator square turns yellow. Good Luck! Hope this helps you!
Mar 04, 2011 | Activision 10 Minute Solution for Nintendo...
The board thinks there is weight on it when there
If you have tried turning the wii and balance board off and then on again (sometimes board can get confused when initializing), you may need to contact Nintendo for repair/replacement. If the board is new, try bringing it back to the store.
May 02, 2010 | Nintendo Wii Fit - Balance Board + Game...
Im having trouble with my balance board keeps repeating step off and press a.after a lot off turning the board over and over if it doesstart it wont give proper weight
the board is most likely defective, I have seen several boards with this problem. I believe it is related to the defect in the right rear foot sensor. try using the board check test to see if it will show the defect and replace the board.
Mar 23, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
"Communication with wii balance board has been interrupted" Just as I'm getting into a step aerobics rhythm the balance board blinks and shuts off its quite annoying. I called a nintendo tech and he...
communication with the wii balance board has been interrupted every time we use the board for any exercise. We have synced many times, but still is happening. Is there any other solutions of what to do besides send it back and pay $60 for a new board from nintendo?
Aug 28, 2009 | Nintendo Wii Fit for Wii
On some aerobic games, particularly the step aerobics, it does not register my footwork correctly, and on the moves where you lift your foot up it will not recognise that at all.
Make sure that the balance board is set up where the blue power button is facing AWAY from your Wii/TV.
If it is set up correctly, then run a diagnostic on your balance board (see instruction booklet).
Regrettably, these boards have a bit of a history of one of the 4 sensors going out. If this is the case, then ensure your product is registered at www.nintendo.com and contact their customer service department.
Apr 08, 2009 | Nintendo Wii Fit for Wii
While working out the system stops frequenty.
Note that the sensor bar does not interact at all with the Balance Board. It seems that you may have a defective unit. Since you have tried brand new batteries, my suggestion is to open a ticket with Nintendo through their website.
Feb 01, 2009 | Nintendo Wii Fit for Wii
Wii Fit Board not working
make sure you have the board the right way around! i know it sounds silly but mine did this and all you have to do is make sure the power button is facing away from the tv! i dont know if that solves your problem but it solved mine!
Jan 11, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
I'm trying to go through the setup to WII fit. My child did the body test with no problems a couple of days ago. I keep getting an error (fidgeting) when I try to take the body test.
Please be a bit more detailed in the problem. The Wii Fit Balance Board is very sensitive to weight shifts. Ensure that you allow the board to calibrate properly. To do this, I would suggest the following steps:
1) Place balance board on a sturdy, flat, smooth surface. If you have average-shag carpet, be sure to use the little adapters that fit over the feet. If the carpet is too thick, then it will NOT work properly. You may want to consider a small piece of plywood or something similar to set between the carpet and Balance Board.
2) Don't step onto the board until it has calibrated (this is when the board establishes its zero point). It will clearly say "Starting Up" followed by "Ok, Step On." After this, you can generally stay on the board unless a particular routine asks you to get off or for some reason it needs to recalibrate.
3) Finally, you must ALWAYS back out all the way to the Wii Fit Plaza (where you pick your Mii) if you change players. Once the board is configured for one player, it will only be suitable for that individual. Its sensitivity is based on an individuals weight. For instance, if the board is calibrated for a 3-year old's Mii, and an adult decides to play any of the routines on that Mii, the board will be over sensitive (calibrated for the lighter weight). Conversely, if an sdult's Mii is selected and a child plays a routine, the board may not detect the movement.
I hope these steps will help. If not, please offer a step by step explanation on what you are doing and I will try to reassess your situation.
Thanks!
Dec 29, 2008 | Nintendo Wii Fit for Wii
Wii Fit Board asks me to step off and press A all the time
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 04, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
23 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
