Question about Minolta Di151 All-In-One Laser Printer
The printer is giving me a code J-2 - Minolta Di151 All-In-One Laser Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Isn't that a paper jam? If so you may have a piece of paper somewhere lodged in your printer, Check all moving parts to see if you see anything.
Laser printers are more sensitive than Bubble Jet.
Posted on Oct 12, 2010
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
What do I do when my printer gives me a error code of e748-2024?
recommended main board 1reseat everything on the boards and the connection between the two there is a comms problem between Cont 1 & Cont 2
Sep 01, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
CANON PIXMA SCAN CODE 2,151,44
I have a PIXMA MP340 printer/scanner--prints fine but when I try to scan, it gives me error code 2, 151,44.
Nov 06, 2012 | Canon PIXMA Office Equipment & Supplies
My cannon ir 3300 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
My cannon ir 2200 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
Sep 09, 2010 | Office Equipment & Supplies
U2-40
enter code (# interrupt C inetrrupt)then give 16 then press copy.
Jun 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
Sharp Model AR 5320 giving F 2 code please
Toner cartridge problem, try another cartridge, a old one if you have.
The toner must be AR-016T.
Feb 08, 2010 | Sharp Office Equipment & Supplies
Machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Dec 30, 2008 | Brother MFC-8860DN Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Error code 0xd05d010d
Please follow the below given instructions to resolve the 0x.... error on the printer front panel.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by following these steps:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold + and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Dec 13, 2007 | HP Officejet 5610 All-In-One InkJet...
Minolta Di151 All-In-One Laser Printer Logo
117 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
