Question about Home
The machine keeps ringing bit it does not receive fax , on scan it display call service 3
  • 10,865 Answers
Hello. We thank you for choosing fixya. Please reenter your problem under the category of telephones or fax machines. Thanks.
Posted on Oct 13, 2010
How do you get the fax machine to work?
First, make sure that the printer is connected to an active phone line. The best setup would be to connect the printer straight to a wall jack and the other end of the phone cable should be connected to the line port at the back of the printer.
For receiving faxes, check the fax settings > Ringing and Answering. Check if the Auto Answer is enabled and check how many rings the fax will pick up any faxes sent to your number. If you have an answering machine connected to the same line, set the printer to pick up 3 rings higher than your answering machine. If you have a voicemail service, you'll need to get a distinctive ring feature from your phone provider.
To get more information on how to setup the fax, check this manual: http://bit.ly/PCKt7z
Sep 05, 2012 | Lexmark "x264dn multifunction laser...
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
How activate auto answer?
1 Press {AUTO ANSWER} repeatedly to display the following.
FAX ONLY MODE 3 RINGS
The display will show the ring setting in FAX ONLY mode.
The {AUTO ANSWER} light is ON.
2 If you wish to change the ring setting, press
{A} or {B} repeatedly to display the desired
setting, and press {SET}.
How faxes are received
When receiving calls, the unit will automatically
answer all calls and only receive fax documents.
Mar 08, 2012 | Panasonic KX-FL611 Plain Paper Laser Fax
1. Fax answers on long distant rings. 2/ Can not receive faxs. 3/What does Tam#ID =11 mean?
1.- Distinctive Ring service from your phone company
2.- Cannot receive faxes
3.- Telephone Answering Machine (TAM)
Item 1 check page 31.
Items 2 and 3 check Troubleshooting pages of the Panasonic OPER-MANUAL
Jun 23, 2011 | Panasonic Office Equipment & Supplies
Not receiving faxes. Machine just keeps ringing.
Make sure fax is not set to TEL mode...it will keep ringing and never answer. It should be set to FAX. mode.
Mar 15, 2010 | Office Equipment & Supplies
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
Cannot recieve faxes
I just spoke with customer service live chat.
-press the "Fax Mode" button
-press the menu button
-The Fax menu screen will be displayed
-press down arrow button 5 times until the screen displays "Ringing and Answering."
-press the select button
-the display will show the "Ringing and Answering menu
-press down arrow button 4 times untip "Pick-up On?" is highlighted
-press the right arrow button 2 times until the screen displays "1st ring"
-press the "select" button and now "1st ring" will be set as the default.
Apr 01, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
