My sd card shows access denied - Computers & Internet
    Problem Solver:
  • 19 Answers
Check the format and also if there is a little switch on the side in the lock position. A little more description might prompt a better answer. Model or manufacturer would help. Also the OS it was being used in.
Posted on Oct 12, 2010
Why am i not able to access D drive
if your using a micro card. Its lock. Take out the card and unlock
Sep 02, 2014 | Lenovo Computers & Internet
Msdc read sector donot read memory card solution
Hi
For cards like san disk you have to unlock and remove the password in the drive that is denying user access. And then you have to use a recovery tool to recover back photos from sandisk SD card. A Tool that worked for me more effectively is..
http://www.advancedphotorecovery.com/recover-photos-from-sandisk-microsdhc-card.html
Mar 16, 2013 | SanDisk 2GB microSD Memory Card
How i fix msdc write sector error in memory card..........
sir i have a 2gb memory card but its not be deleted then i try to delete this , after loading show this message MSDC wright sector error, & then moved any file then show this message "access denied" please help me.
Dec 17, 2010 | Electronics - Others
Not able to format or add anything to mmc
This is usually caused by the SD card adapter, and is nothing to do with the camera or the microSD card. On the SD card adaptor there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked. (In the above picture, we are talking the left adaptor, and the left hand side - just where the line splits the red from blue).
If it is a damaged / "cheap" adaptor card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to move the slider to locked, then back to unlocked. The replace in the MMC reader and see what you get.
Mar 02, 2010 | SanDisk 1GB microSD Memory Card
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
I can't delete any files of my phone!
You can try removing your SD Card and changing the lock/unlock switch to off on the left edge of your SD Card.
Apr 21, 2009 | HTC Touch Diamond Smartphone
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
My 320GB External hard drive is showing access denied when I click on it.
the file you need is called takeownership you have to google for it as it's in one of the forums the file is in the form of a zip file and when extracted you select the takeownership and install a little code into your reg and when you select a folder right mouse button on it and select takeownership this willl get rid of access denied garbage and give you full control over the folder and you do the same on any hard drive.
hope this will solve problems of access denied
Nov 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
My SD Card whiped?
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 01, 2008 | HP Photosmart E327 Digital Camera
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
