I have the same problem, NOTHING to do with batteries.BUT if you press the that blinking (red) button and hold it down and THEN press the option you want (channel +/-, volume +/- etc) the controls work. Im looking for an answer aswell to return it to its previous state where I dont have to do that!
Hello Four digit universal remote codes for Hisense TV are: 0073 0182 0216 Five digit universal remote code for Hisense tV with RCA RCR312W remote control is: 10748
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's. If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't. So you have 2 options: 1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual: Turn on your TV Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice Enter 9-9-1 and the TV button will blink twice Press and release 1 and the TV button will blink twice Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off Press Setup once to lock in the code and the TV button will blink twice If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so 2 - you get a remote that is compatible with both. The only one i could find is http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
here is a site that gives you all of the remote codes for your comcast remote. Scroll down to comcast and select the correct comcast model. It will show you all of the codes for everything
Even though this problem is a year old, I thought that I would share my solution for Remote codes for a Verizon FIOS.
I tried asking Verizon, and Hisense for a code that would work as the published codes did not work to program my Verizon remote. No answer from either.
I accidently discovered that the codes listed for LG worked, in fact the first code listed worked. I surmise that Hisense uses the same codes as LG.
If you are at wit's end then try the LG codes.
By the way. I tried stepping through all codes several times but no success with the Verizon instructions. The fact that the LG codes worked, indicates that the Verizon solution is wrong.
I have a 32" Hisense and the code for Comcast is 10178.
