Question about Sub-Zero Bottom Freezer Refrigerator
The refrigerator makes an intermittent loud buzzing sound that lasts for about 5 seconds then clicks off
SOURCE: Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Posted on Oct 19, 2006
davidpsr
  • 222 Answers
SOURCE: intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Posted on Jun 27, 2009
SOURCE: my maytag refrigerator started making a buzzing
I have the same problem. It is ice buildup around the evaporator fan that begins as a buzzing (the fan blades hitting the advancing "glacier"), which ultimately stops the fan and then the freezer/fridge stop cooling. Just pull the lower sheet metal from the inside rear of the freezer (need to remove some screws from upper sheet also) and chip the ice away. I've got a question in to Maytag now to see how to prevent this from recurring. I've had to take the thing apart 3 times in 2 years.
Posted on Aug 27, 2009
  • 1218 Answers
SOURCE: My Amana refrigerator with bottom freezer thaws
The techs are correct. The sound you hear is the compressor trying to start.
Most appliance parts companies sell what is called a
start kit or hard start kit. I personally use the "ic13".
It has given me the best results but it's a **** shoot.
If you feel like gambling, try it. As well,
It is very important that you run the machine with the back cover in place. It ducts the air to the condenser . Very important. Make sure the condensor coils are clean, as well.
Posted on Oct 19, 2009
  • 311 Answers
SOURCE: The refrigerator keeps making a loud buzzing
Sounds like your starting components are bad on the compressor. If the freezer section begins to loose temp then this is probably the case. They will try to start the compressor and then it will kick off on its overload. However this will usually occur every 10-15 mins when they are completely toasted. Your compressor may be starting up part of the time and not starting the rest. Either way you will probably need new starting components on the compressor. You could also check to make sure your condenser fan motor is running (in the back of the ref behind the access panel) because this could cause the compressor to overheat but usually wont cause a buzzing noise.
Hope this helps _MJ_
Posted on Feb 07, 2010
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
Sep 26, 2016 | Frigidaire Refrigerators
Emits a loud coarse noise, about 10 seconds long, intermittently throughout the day & nite
What type of compressor does it have? Some brands use a compressor that makes this sounds every time when it starts up. And its normal. Last for 5-20 seconds.
Feb 17, 2016 | Refrigerators
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
Kenmore Elite bottom freezer making a clickbuzzzzzzclick sound
you need to check to see if you have a control board by compressor.if not change relay and overload to compressor if you have a grey box with a board in it then you need to most likely change it
Mar 14, 2009 | Refrigerators
Every 3 minutes the fridge makes a loud buzzing sound. seems to come from compressor.lasts about 10 seconds then stops with a click
your start system for the compresser (relay and overload) is out you will need to replace go to www.apdepot.com to look it up by your model number
May 30, 2008 | Maytag Refrigerators
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
139 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
