I have just made a 27 minute movie, successfully, to a previously blank DVD, using Pinnacle Studio 12 software. Now I am trying to use the same retained captured and edited files to produce 2 more copies from, but I keep getting an error message, saying: Export error: real time, c:\users\owner\appdata\local\microsfolder\render/my movie. Is it possible to make more than just the original movie to a DVD, and if so, how do I go about making copies?
    Genius:
  • 1,478 Answers
If the DVD is not lock when you first store the first movie, or if the space as not been exhausted, you can store more movies to it, first check the available space on the DVD, if it is still large, follow the procedure you use at first to store the movie to store other ones you intend to store.
Posted on Oct 12, 2010
Flicker on dvd
Well I am having the same problem
My pc crashed so it was re built
installed windows 7 same problem
then went back to XP same problem
I reinstalled pinnacle 12 ultimate BUT can not down load the the patch via the net its not avaible now
We need to get this patch
Sunjith sewsunker
Jan 25, 2013 | Pinnacle Studio Ultimate 12 for PC
Why does my dvd freeze frame after using pinnacle 14?
I have made about 5 DVD's all under a half hour and just made one over 45 minutes and am having the same issue. When I play the DVD, it will freeze in the same spot about 15 minutes into the movie. I have read that using a different burn tool instead of Pinnacles may work. Also, de-install the software and re-install. I have not tried yet, but will let you know. After doing some quick searches, this is a common problem with Pinnacle.
Jul 24, 2012 | Pinnacle Studio 14 HD
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
I can't make a 16 minutes movie on my Pinnacle studio ultimate 12 program. I didn't have a problem to burn a 20 seconds MPEG file.
Hi and Welcome,
Click on the completed project in the timeline, go up to "Edit," click on "select all" in the dropdown menu, then RIGHT click anywhere in the now-highlighted project and select "Copy."
Now go back up to "file" and click on "New Project." Your current timeline will close (don't worry. It's saved,) and a new blank timeline will open. Left click anywhere in the new timeline, then right click and select "paste."
After a terrifying period when you think nothing is happening, your entire project will suddenly appear in the new timeline.
Save it with a new name, then try rendering again.
Nov 01, 2010 | Pinnacle Studio Ultimate 12 for PC
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Whenever I try to burn a disc on Pinnacle 12 Ultimate the burn fails. Then it tells me that I need to use an empty or re-writable dvd. I then used an empty re writable dvd and still the burn failed, and it...
The new Pinnacle Studio 12 includes more than 25 new features and more than a ... This is an upgrade. so you need Pinnacle studio 11 first. ...... could you tell me if u have tried that on a different computer with out ..... of data of the Pacific and burn it then because a compact disc and then the ...
thepiratebay.org/.../Pinnacle_Studio_12_Ultimate_-_by_Mick_(Full_Version)
Jul 18, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When saving movie to DVD Disc it does not play on DVD machine
you just cant save a movie to a DVD and play them on DVD players....it just does not work that way
you need to write them properly using a software like Nero
Create DVD/CD/Mini DVD etc in Nero is a good option
Nero is a software for audio and video editing and recording.
Dec 06, 2009 | Pinnacle Studio Ultimate 12 for PC
Pinnacle 10 dvd burning
have you tried rendering as an AVI file ... then burning???
also, check the drop down tab to make sure in the "make a disc" section that
there are not 2 listings for the dvd choice ... if there are... then select the second
dvd.. and tell it to burn...
or make the AVI and use Nero 8 or 9 to make the DVD.
my version 10.8 is whacked...
upgraded to 12... it's working fine... finally.
bbell
Dec 14, 2008 | Pinnacle Studio Plus 10 Full Version for...
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
