Question about Bushnell ® Elite® 3200 3 - 9x40 mm Ballistic Reticle Riflescope
After sighting in the scope,I take a few more shots and have to readjust the scope.
  • 243 Answers
This symptom is typically caused by slippage of the scope in the rings, you should tighten the ring screws to 15 inch pounds or so. Many ring sets are slightly misaligned or poorly machined.
If you continue to have problems, you may need to use a ring lapping/alignment tool (available from midwayusa, (http://www.midwayusa.com/Search/#wheeler%20scope____-_1-2-4_8-16-32). This will increase the surface of the ring that actually contacts the scope, thus increasing the clamping force and friction to keep the scope in place during recoil.
Don't know what type of rings you have, but Leupold makes excellent rings. I have not found it necessary to lap these rings to date, even on my 45/70.
Other issues may include loose mount screws or loose ring to base mounts.
Mount your base screws using 15 to 20 inch pounds of torque and blue locktite. Torque your ring to base screws to 30 inch pounds or so.
If the scope is slipping in the rings, a quick temporary fix that might help is to apply rosin to the inside of the scope rings to increase friction. I have also used a dab of rubber cement as a temporary fix.
Posted on Oct 14, 2010
My Gamo Scope
Try Loctite Blue on the screws or buy a decent scope. Gamo are entry level. If you need to remove the scope frequently, invest is some Parker Hale 'Roll Off Mounts'.
Nov 15, 2016 | The Optics
Need Rossi 243 single shot rifle sights
gunsmith is the only place I KNOW
Feb 18, 2015 | Optics
I can't adjust my scope! An it's driving me crazy!
I have a simple solution which will take two shots for bull's-eye. You will need two people you set your sights on a bull's-eye after the shot what you will do is hold your gun or rifle steady at the bull's-eye while the other person moves the cross hairs on the scope to the bullet hole
Aug 16, 2014 | Optics
How do you sight in a redfield scope
Your scope should be "in the ball-park" out of the box. This ball park will of course be determined by the height of scope rings you put on your rifle. The taller the scope rings/bases the lower your initial shot... Go to a range or safe outdoor shooting area. Put a large target up at 100 yards, 16"x6" will usually do. Aim at the bulls eye, and click off a round. Use a spotting scope, binoc's or your scope to see where your shot has hit. If it is off the paper and no where to be seen, click off a shot one foot high, check paper, repeat one foot low, one left, one right until you find your shot on paper. Once you find your shot, you will need to adjust the windage (left to right) or elevation (up to down) by using the turrets on the scope. Part of the trick in sighting in your scope is to remember if your shot is high, then you need to crank the turrets in the "up" postion (if it shoots left, turn turrets to the left, and so on). This part is sort of counterintuitive, and may feel foreign. Once you get your scope on paper, continue to adjust until you are hitting consistently 1 inch above bulls at 100 yards. Shooters benches and rifle rests help in this process, but it can also be achieved without. I hope this helps. D
Jul 26, 2014 | Redfield Optics
Throwing one of three shots
Not enough information. Is it consistent? Are you using the same ammunition? Distance? Rifle? Iron sights or Scope? etc.
If you are using a scope, it is possible that the scope is loose. If you are firing off-hand, it is probably you. If you are shooting at 1000 yards, you group is actually pretty good.
If you are benchresting your rifle, make sure you are not resting the rifle on the barrel, this can throw shots all over the place.
Apr 09, 2014 | Optics
I have a diana 177 air rifle that keeps going out of sight every 2 shots,could the inner barrel be broken?
does it have a scope or iron sights? If it has a scope make sure your scope mounts are tight. you may have a loose lens inside your scope. Not likely that you have a broken barrel
Jan 17, 2013 | Washing Machines
New nikon monarch III 4-16x42bdc. elevation is mased at lowest set still bore sighting at 2.25 above 0 with windage centered. actual shot is off target.
have you shot it yet???? dont forget bullet drop!!!! but if it shoots to hight thats easy to put right,,,most of the time its a mount fault, but undo the front of the scope mount and slid 3 bits of 35mm film under the scope then nip the scope down on the film strips,,this will lift the point of aim past what you need,,,,
Oct 05, 2010 | Nikon ® Team Primos® 3 - 9x40 mm BDC Rifle...
I shot my 30-30 to make sure my scope was sighted in correctly, after the 2nd shot my scope blurred up now i cant see threw it.i had my gun setting on bean bags on an inside shooting range, i have tried...
well if its not foged up then the scope has shook its self to bits,,, it happens like that, a lens comes loos and it just go's out of focus, sorry there is nothing you can do to put it right
Nov 30, 2009 | Optics
My elevation and windage adjustments aren't moving my scope. I shot 4 times and my group is 1 inch. Problem is I adjusted my scope between all 4 shots. I'm consistently shooting 7 inches high and 3 inches...
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
Nov 23, 2009 | BSA 3-9x40 Deer Hunter Riflescope
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Bushnell ® Elite® 3200 3 - 9x40 mm Ballistic Reticle Riflescope Logo
208 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
