Question about Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range
I have Kenmore Elite Model: C970-688302/serial NF81504730. The burner sensor/indicator light for the top left corner burner is always saying "HE" for Hot Element. It never used to do this. It's only about 3yrs old. We've tried unplugging/plugging back in and even flipping the breaker (which is pretty much the same as unplugging/plugging it back in), and nothing has worked. I re-cleaned the top of all the burners thinking that maybe it was sensing something because there was some food burnt on it. That didn't help either. The burner itself is not hot to the touch, but I'm just concerned it may develop into a fire hazard. I have 3 cats and 1 dog that are inside and I don't want to loose them (not to mention my house). Anything I should be looking for? I know these flat-top ranges are expensive to replace the burners for...so I'm looking to troubleshoot BEFORE I have to pay someone to tell me some small "fix-it". Thanks.
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric range
The problem is caused by a shorted BROIL relay on the Electronic Oven Control board. I have experienced this problem before. The oven will continue to heat because it's being provided a constant power source. You are right to assume the reason for the oven temp error. This is common too.
Here's a TEMPORARY fix you can try:
1. Secure power to the range and remove the back panel from the console.
2. Unplug the BROIL element wires from the EOC and wrap them with electrical tape. It should be marked on the circuit card.
This will leave your broiler out of service, but you should be able to use the bake function. This should only be a TEMPORARY fix. The real fix is to replace the EOC. In the mean time, DO NOT leave the range plugged in while not in use (especially, if you are not going to be home, or while sleeping). This could be a definite fire hazard. If you post back with your model number (located around the oven door, or bottom drawer opening) I can give you an idea of how much the EOC would cost, and give you advice on how to replace it.
Posted on Feb 11, 2008
  • 49 Answers
SOURCE: cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Posted on Mar 08, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 10865 Answers
SOURCE: Element on light won't turn off when stovetop is cool
You have a burner sensor that is stuck in the open position sending the signal that the glass top is hot. This is not a safety concern but if you want the light working properly you will have to replace that sensor. Perhaps you can now call around and tell the various repair people what you need to have changed and they will be able to tell you how much it will cost.
Posted on May 12, 2009
  • 969 Answers
SOURCE: We have a Kenmore model #790.96011407 range with
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Posted on Jun 27, 2009
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
I can not open control console in order to fix lid switch for Kenmore Elite Washer 110.15962401
First unplug the power cord. On the top corners of the back of the control panel there are two screws, one each side. Remove these first. At the front corners where the control panel mounts to the case top there are spring steel clips, which compress and snap into a slot in the top of the case. A putty knife pushed in between the panel and the case will compress these springs and release the front of the panel. this link will take you to Sears parts and an exploded view of the machine top.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/All-Products-Parts/Model-11015962401/0583/0153200/K0407007/00002?blt=06&prst=&shdMod=
Dec 25, 2011 | Washing Machines
Where to find the model seriel numbers
Hello there and thank you for choosing fixya
Ok normally the model number will be posted on one of the following
i have the diagram listed below for you ok this is for both gas and electrictbirdfan1_14.jpg
Jan 21, 2011 | Ovens
Just bought a house with a Kenmore ceramic top range. model is 790.9601. The red light on the top left of the panel that indicates that a burner is hot keeps blinking even though the range hasn't been...
Sorry to read about your problem, I hope this helps you out.
those are hot plate sensor's just to let you know, that glass maybe hot, they will turn off when the stovetop cools down.
now if you happen to put a hot pan on the cook-top, lets say from the oven. the lites will come on.
in your case I think is is defective and staying on
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore Kitchen Ranges
Top electric oven will show an F3 error after being turned on and will beep. Botton oven works fine. Jenn Air electric oven model JJW927AAW. Serial number 11993640WO
HI thanks for your question.. code F3 says to replace the oven sensor, located in the oven. top left corner. Replace the oven sensor. Thanks
Dec 17, 2010 | Jenn-Air Ovens
What does the fault code F28 mean onf the kenmore elite HE3t mean model #110.49972602
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Kenmore Washing Machines
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
My kenmore elite washing machine always has an unbalanced indicator, even if i run it empty.
Check the balance load sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite dual fuel range top ignitors clicking like lite mode is on, but it's not.
You probably have a shorted spark module. send model # for more help. Hope this helps!
Feb 16, 2009 | Kenmore Kitchen Ranges
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 92022 / 92024 / 92025 / 92029 Electric Kitchen Range Logo
195 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
