Question about Kodak EASYSHARE M1063 Digital Camera
I dropped the camera and the lense is stuck in the open position and I can't retrack the lense or turn on the camera
  • 11,896 Answers
Make sure there are not dents or debris preventing the zoom or lens to get stuck open. Another thing you can do is try and manually close it while pressing the button.
Posted on Oct 12, 2010
The camera lense is stuck open and not will close
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
Jul 19, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
The camera has been dropped while the leanse was exrtacted on now it wont extract or retrack also it will not turn on
If you push in the lense it will go right back in. Push as hard as you can. trust me, My Exlilim fell and the same thing happed but i pushed it in and it worked =)
Oct 10, 2009 | Casio Exilim EX-Z29 Digital Camera
Kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
CAMERA DROPPED AND LENSE IS STUCK OUT AND CAMERA
your len's mechanism is damaged or jammed. It would be too expensive to repair!!Hopefully this helps
Jul 24, 2009 | Polaroid i631 Digital Camera
Camara lense is stuck wont retrack...making bleeping noise
I have read about gently banging it on something hard but it wont work on my camera...
Jul 13, 2009 | Samsung Cameras
I have the same problem
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 23, 2009 | Samsung Digimax S630 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Lens is stuck open/extended
Im having the same problems with mine, I can view my pictures, but the lenses is stuck out, beeps a few times and then I get the E18 error. I tried everything at http://www.e18error.com/repair.html but still no luck, ready to take it apart and see what is stuck
Aug 20, 2007 | Canon PowerShot S2 IS Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
54 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
