Question about Friedrich D50C Dehumidifier
Friedrich dehumidifier I have a 1 1/2 year old Friedrich dehumindifier. The fan, display, and everything else seems to be working but it is not taking any moisture out (no water in the bucket). Any suggestions to check? Thanks
  • JohnOB Jun 02, 2008
    Thanks for the response. No ice on the dehumidifier, temp is above 65, and humindity is high. Do you know whether the condenser might have a reset switch?
    New Friend:
    Problem Solver:
  • 10 Answers
Dehumidifier works great. Replaced an old unit with this one. Has removed a ton of moisture from the air. Maintains a comfortable temperature in our basement too. Easy setup.
Posted on Jul 04, 2015
  • 525 Answers
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • David Emmel
    David Emmel Jun 03, 2008
    Ok, If the parameters are met and the fan and compressor is running, the you would have insufficent freon , possibly due to a leak, or a weak compressor.
It is making a lot of noise. Still seems to work.
I get this complaint a few times a month , what I usually find is that the circulation fan has a build up of fuzzy lint on the blades and it throws the fan out of balance (hence the noise) a soak in a warm water/soap solution usually takes care of it , disassembly is required for this , I usually charge two hours labor for this
Dec 01, 2015 | Friedrich D50BP Dehumidifier
Everything works great except the fan. Fan won't turn on at all. Any recommendations?
Check the power to the fan motor or capacitor. One or the other needs to be changed.
Sep 30, 2015 | Friedrich D50C Dehumidifier
Unit forms ice on back coil. Please advise
The freon in the unit is low. You probably have a leak.
Jul 13, 2014 | Friedrich D40 Dehumidifier
Power s on unit doesnt run no fan nothing
Mosr dehumidifiers have a switch that shuts the unit off when the water tank is full check this float to make sure it is not stuck in the off position also empty the tank if it is full.Hope this helps.
Dec 10, 2013 | Friedrich d70bp dehumidifier,70 pt.,115v
3 or 4 years old. the entire unit shuts of every 2 or three minutes. it stays off for a few seconds, then restarts
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
-0-0
Sep 11, 2011 | Friedrich D50C Dehumidifier
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
Fan runs, seems to work ok... but not pulling water out of the ai
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 16, 2010 | GE AHK40LK Dehumidifier
Dehumidifier turns off
Take out the fan motor and test it with direct power supply if it did not work more than 2 min,change the fan motor.
Jul 11, 2007 | Friedrich D50 Dehumidifier
Friedrich D50C Dehumidifier Logo
539 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
