Question about Broksonic SC975 19 in. TV/DVD Combo
Sometimes my tv says incorrect disk when I'm trying to watch a DVD. And sometimes it skips with a brand new disk. How do I fix it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
If you do not have a good disk cleaner, I would suggest you use one. Some disks wont play if the lens has film or dirt. There is a kit you can get at Radio Shack, Best Buy, or even Walmart. It is a wet dry system, couple of drops of alcohol, and you clean your dvd player. It has audio on it and you can follow the directions. They also advise after 10 hours of use to do a disk clean up on your system I also do my CD players too, Also on your PC. Hope this helps.
Posted on Oct 12, 2010
Janome 11000 skipped stitches if any are even made at all
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
Mar 05, 2016 | Janome 11000 Memory Craft Special Edition...
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
I havent had my tv/DVD combo insignia tv for even a year and the DVD player is messing up. The whole time its reading the disc it plays, there is a loud grinding sound. Sometimes it wont even play my
laser pickup unit fault. Check and replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
May 15, 2017 | Insignia Televison & Video
Disc skips when watching my DVD
If you switched DVDs and you plugged it into an electrical outlet and it is still happening, you should take it in to have someone look at it.
Jun 17, 2008 | Polaroid PDM-0082 Portable DVD Player
After recording a one hour episode, won't recognize the dvd.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media.
tom
Apr 23, 2008 | LG DR787T DVD Recorder
Wrong disc on screen
If you DVD player is damaged, and u have external AUDIO\VIDEO inputs.Buy a $59.00 scan DVD player & save yourself a $100 repair bill.
The DVD heads coud be internittan { sometimes it works & sometimes i don't } U could have issues with the country codes that tell your DVD where the DVD CD was made at or where is was recorded.
Mar 26, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
DVD skipping? is something wrong or what..hellpp
It may not be your tv, itmay be your dvd player, open the tray and blow into the tray compartment, or wipe off the lens. When the lens gets dirty, its like trying to look out through a dirty window, and when the lens goes over a part of the dvd with the area that is dirty, it cant read it so it skips over it.
Hapy new year, hope this helps
Dec 31, 2007 | RCA TruFlat 27F520T 27" TV
All dvds skips evan brand new ones
Return the unit to the store which you purchased it from. You have an internal problem with the scanner (led) You can first try to clean the led this could be your problem. They sell lens cleaning dvd disks. try it, you have nothing to loose. If this does not work, just bring it back.
Dec 27, 2007 | Coby 5.1 Channel DVD Player with Home...
Dvd player doesn't work
you moust troaien CD&DVD clearns for the best working
May 05, 2007 | Toshiba MD13N1 14 in. TV/DVD Combo
All DVD`s installed in player skip .Also DVD`s that showed title donot now.
first thing i would do i clean the lens with 90% isoprople alcohol and a q-tip, if that doesn't work watch the laser eye again and the movement is the laser look like it tries to catch up???
i would put a dc volt meter on the motor and the motor should stay at lower voltage if it climbs then there is something with the rails or worm gear. let me know what you find out.
Aug 23, 2006 | Yamaha DVR-S120 DVD Player
Broksonic SC975 19 in. TV/DVD Combo Logo
82 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
