Question about GE Washing Machines
During the wash cycle, the water and suds overflow and flood the launry room
  • 755 Answers
Try turning off the water at the supply after the machine fills up and see if this still happens. Chances are your fill valve isnt shutting off when its supposed to.
You should also check for power to the switch after the unit starts the wash cycle and see if it is still energized. Which would be a sign of a damaged timer unit.
Posted on Oct 12, 2010
Oversudsing Stops cycle
Oversudsing causes some dishwashers to trigger the flood switch. This is because the suds overflow and leak through the air holes. As soon as the flood switch is triggered inside the dishwasher it shuts itself off.
Wait for the suds to disppear and the flood switch to dry off. Use recommended type of detergent.
Apr 20, 2013 | Dishwashers
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer error code
Your TECH SHEETS mention "Sud" If too much detergent was used. Why? You get that computer thinking suds is in there and the machine is gonna go into a tailspin. Because of the low amount of water
used in HE machines, it is important
to use an HE detergent (low sudsing)
which is specially formulated to work
best under these conditions. The two
most important considerations of a front loading washer are sudscontrol and soil concentration.
First, the tumbling action in an HE machine generates
more suds than a top loader. Tumbling the clothes in and out of the water breaks the water surface
causing air to be trapped in the solution,
creating suds or foam. Multiple problems
can occur from oversudsing, such as
flooding from suds overflowing out of
the machine, formation of a suds cushion
during the tumbling action which reduces
mechanical energy,and “suds lock” which prevents
the machine from effectively spinning out the
water. In the situation of suds lock, the
machine tys to FIX the foaming poroblema by
stopping the cycle momentarily to allow
the suds to dissipate and then adding cold
water. This routine the machine goes
through to correct for over-sudsing results
in loss of energy and water savings and
can significantly lengthen the cycle time
(sometimes by as much as 2x). HE detergents
prevent over-sudsing and allow for better rinsing of suds. HE detergent matters in soil management also. Though HE washersuse about 1/3 of the water of a
top loader, the concentration of soil in the
load is much higher due to the larger
loads. To handle the higher amount of
soil, many HE detergents are specially
formulated with soil suspending ingredients
to prevent soil from re-depositing
onto clothes. Only use detergent with HE marked on it. Use the correct amount.
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
4. Check/clean drain pump filter of foreign objects.ec9f016.jpg
5. Plug in washer or reconnect power.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle. Your tech sheet will be behind the bottom panel and will resemble THIS Suds is on page 6
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
The dishwasher was full of soap suds but most of the water drain
Suds? If you use dishwashing detergent you shouldn't get suds. If a small amount of sink type dish soap is left on a dish before loading it into the dishwasher this can happen. I would use several rinse and drain cycles with the racks and dishes removed until the suds are gone.
Never use any type of liquid dish soap made for sinks. The same thing that makes suds in the sink will make even more in the dish washer.
Hope this helps!
Feb 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
GE WASHING MACHINE GWSR3090W
check the inlet valve when it flood unplug power the water should stop if it doesnt its the valve.if it does it could be the pressure switch.hope this helps.
Mar 08, 2008 | Washing Machines
Water overflow
Are you on a well? Often people with a lot of sediment in water get sick of the screens in water valve plugging up so they remove them. NEVER remove these screens. If any sediment gets into valve it can hold it open causing flooding. If you unplug unit and water still comes in you must replace valve.
Oct 08, 2007 | Maytag LSE7806A Top Load Stacked...
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
