Question about Canon Cameras
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
  • StefanScerri Jun 01, 2008
    Hi HeavyDLB
    Thanks for you very thorough answer. I wasn't using zoom in the first place so that was not the problem. I tried with tripod as you suggested and things got much better. I guess I wasn't getting the distances right as you said. Probably was getting too close with for Macro setting since when I switched to Supermacro results were much better. Macro works fine if you keep at least 10-15cm away from the subject as you said.
    Much obliged.
    Regards
    Stefan
    Scholar:
  • 46 Answers
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
  • David Bland
    David Bland Jun 01, 2008
    You're welcome. Glad it helped :-)
    HeavyDLB
Though the photos in autofocus are fine and very sharp, the view through the viewfinder is blurred,even when i press the button half way down to focus the lens. this has only just started happening. have i...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
Nov 29, 2010 | Canon EOS 450D Digital Camera
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
Regards
Nov 29, 2010 | Canon EOS Rebel XSi Digital Camera
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
Super macro
Press the macro button once to get it to display the Macro Mode sign. Press and hold it after that to get it into Super Macro
Once you are in Super Macro, you can't move the lens so you MUST use the Manual Focus (MF) button that is located right above the Macro toggle button. While holding the MF button, use the 4 way directional pad to focus in and out. Press the Up and Down to focus.
You have to be REALLY close for Super mode.. less than about 6 inches
Aug 16, 2008 | Canon PowerShot S5 IS Digital Camera
The focus on my cannon powershot A540
Do you focus and then push the shutter button half way down to lock in that focus? Then all the way to take the picture?
Do you support the camera on a tripod or kneel down and support your arms on one knee or lean against some object to keep the camera steady> You can even press your arms tightly against your body before you focus and shoot. And be sure to press the shutter button very gently when you shoot so the camera will not shake or move.
Do you have the camera on the right mode for the photo you are attempting to take? Such as night/macro/action/ etc. Try taking photos on just the automatic mode to see if you can get focused shots. Make absolutely sure your camera is not in Macro mode ( a picture of a little flower on the screen) unless you are doing extreme closeup shooting.
Go to your menu>then setting> then set your camera back to default settings if you can. Or if you are unsure how the camera is set. If you do not have your manual you can go to the Canon website at www.canon.com and click on support or downloads and find the manual for your camera and download it. That may give you the answer you need as well.
Please get back to me if you do not have any luck and send along more info such as camera age.
Aug 08, 2008 | Canon PowerShot A540 Digital Camera
I have a canon eos 450d which on the display screen only shows the information I can't see what I can see through the view finder, help please.
you have to enable the live view from the menu. then press the set button on the center of the arrow keys.
when shooting with the live view on, auto focus will not work if you press the shutter button halfway, you should press the button marked '*' to make the auto focus work. the small rectangle on the lcd monitor will turn green when correct focus is achieved.
Jul 07, 2008 | Canon PowerShot A530 Digital Camera
I can't get my Powershot S5 to go into Super Macro mode - Help!
There seem to be two stipulations for getting into super macro mode,
First you must be in scn ("A" or "S" mode's only) and "movie", "P", "TV", "AV" or "M" modes only.
Secondly the zoom Lens must be all the way out.. set at the widest angle.
Best of luck
Jun 14, 2008 | Canon PowerShot S5 IS Digital Camera
How to delete picture from canon powershot s5is
Press the set button located above the menu button to erase a single picture. The set button is like an enter button on a PC
Apr 25, 2008 | Canon PowerShot S5 IS Digital Camera
CANNON S50IS
Guest is quite right - use the macro button on left hand side of lens (holding camera pointing at subject) Press once for "macro" which focuses from 10cm away. If you hold this button in for about 2 seconds, it puts your camera into "supermacro" mode, which gives focus from right up against the lens! (need backlighting for this close!) Supermacro will not work in Auto and Sport mode. Best is to use "AV" or "TV"
As far as viewing your pics goes - rotate the mode lever (You turn this anti-clockwise to turn ON) clockwise and you will see the most recent pic on your LCD screen. Use the left and right direction on the omni selector to naviagate through your pics.
Its a good idea to download the advanced manual onto your pc from the dic supplied. Its an adobe document and very user-friendly.
I hope this helps you.... :)
Mar 21, 2008 | Canon PowerShot S5 IS Digital Camera
Focus
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Nov 24, 2007 | Canon PowerShot S3 IS Digital Camera
Cameras Logo
213 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
