Question about Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor
I have a Dell monitor model #1901FP when my computer comes on the monitor comes on as it should. After only a few seconds the monitor goes blank. You can turn the monitor off then back on the monitor will show the start up screen for a few seconds and then goes blank again. What could be my problem?
The solution I am about to describe refers to a backlight problem, which is most common in Dell 15,17 & 19" monitors. The symptoms are as you describe:
  • You power on the monitor, the green on/off switch illuminates and the display works for approx 1-2 seconds and then goes blank.
  • The green on/off switch stays illuminated but the screen remains blank
  • If you shine a torch into the LCD matrix you can see the display being rendered faintly
  • Switching the monitor off and then on again illuminates the display again for 1-2 seconds before going blank again
This is a backlight fault and is most likely to be caused by the failure of two of the four driver transistors used to light the lighting tubes in the LCD Matrix. This fault is easy to repair if you (or a friend) have a soldering iron and a voltmeter.
Inside the monitor there is an inverter board that acts as a power supply for the monitor and the logic necessary to control the backlights (illumination and brightness control). There are four lighting tubes, which are controlled by two lighting circuits (two lighting tubes per circuit). At the heart of the inverter board is a chip that monitors feedback from the two lighting circuits and closes the back-light circuit down if either of the lighting circuits fail, thus any component failure will exhibit the same symptoms.
The transistors which fail most often cost pence to replace (types C5706 or C5707). However, their failure in unlikely to be the cause of the problem. My first crack at fixing this fault, by replacing the transistors, resulted in them failing again within 24/48Hrs. The cause of the problem will be dry solder joints or loose connections on the high-voltage side of the circuit, usually on the backlight transformer in the effected circuit. If you re solder each of the connectors on the transformer you will save the transistors from blowing again - the transformer generates 1,400Volts for the lighting tubes and at this voltage, arcing across the a dry solder joint, will quickly destroy the transistors again.
No soldering iron? - A complete inverter board replacement is also reasonably cheap and easy repair. These are widely available.
Sorry of this is more detail than you expected but it may help others reading this article.
Posted on Nov 28, 2010
A blue lock appears in the middle of my screen, you can not click on it. It disappears and comes back...sometimes open lock, sometimes closed. How do I get rid of it? Thank you!
http://support.dell.com/support/edocs/monitors/1901FP/en/controls.htm
Go here and look at how to disable the OSD lock; try holding the menu key for 15 seconds on the monitor.
Mar 09, 2011 | Dell E152FP 15" Flat Panel LCD Monitor
My Dell Flat Panel Monitor Model 1901FP goes black after it's on for 3 seconds. The green light stays on. I tried replacing cables. Any Solutions?
Inspect the power supply/inverter board for caps with domed tops first, if you do want to DIY repair down to component level, you can get a replacement board for $30.
http://lcdrepair.us/1703fpt-1901fp-inverter-power.html
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 19, 2011 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
The screen goes blank after I turn on the monitor. When I turn it off and then on again, I can see for a few seconds and then the screen goes blank again.
Look for bad caps with bulging tops/seals first: http://www.lcdrepair.us/1703fpt-1901fp-inverter-power.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us
Sep 23, 2010 | Dell 1703FPt 17" TFT LCD Flat Panel...
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell 1901fp power board problem
Sounds like a loose connection or broken solder point. It could also be a bad inverter or CCFL.
Have it serviced or replaced.
RDO
Nov 16, 2008 | Computers & Internet
Dell 1901FP monitor
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Oct 26, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor Logo
864 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
