Question about Fellowes Intellishred SB-89Ci Shredder
The light is on that indicates the door is open. I have pulled the drawer out and put it back in several times, but the light will not go out and therefore I cannot shred any paper.SB-89Ci
  • Anonymous Mar 12, 2014
    No blue light on "on" button... other lights will come on (if we pull out the bin, that indicator light comes on, but no other response.
    Sergeant:
    Champion:
  • 387 Answers
Try to look for a sendor or a swich by the door
Posted on Oct 12, 2010
How do I completely open a partially opened freezer drawer?
Hello Laura;
My name is Peter. I am a retired field service refrigeration technician.
Refrigerators with freezer drawers are nice up until the time that you need to call a service technician, and find out it cost about 40% more than a top or side by side refrigerator to repair.
If you leave your freezer drawer not completely closed, outside warm air enters your freezer and you get Ice build up on the rail system. It is difficult to see if the freezer drawer is completely closed because the fresh food section doors above block the view.
If you can pull the drawer out part of the way, use a hair dryer directly on the rail system on both sides in a effort to melt the restricting ice. Take your time. This may take several hours at which time you will push and pull on the drawer every 30 minutes until you break the rail system free from ice restriction.
After you have the door free, with a kitchen spatula and a hair dryer heat the gasket around the freezer door gasket pulling the gasket out to repair a possible crushed door gasket and not having a goo seal.
I have gone on service calls where the rail system ice was so built up, all I could do was to advise the customer to unplug the refrigerator for 36-24 hours to clear the ice from the rail system.
This is a common problem with drawer freezers. Next time get either a top mount refrigerator freezer or a side by side. Lower repair cost and more reliable.
Mar 06, 2016 | GE / Profile PFSF6PKXBB
The freezer has a white plastic back panel with vents to blow the cold air into drawers. That thing pulled away (ice formed behind it) - how to put it back?
there is some ice that has frozen the door in a fixed potion, if you have hair dry put on warm point toward where it hinges other than that call some service person to help you.
you mite call the manufacture customer service dept. ask for service
technician, explain whats wrong and see what they say. it never a bad question, or to ask for help!!
www.ask.com/mfg.name/make/model/customer/service/telephone#/
Oct 06, 2015 | Refrigerators
Cd door won't open
That happens when you push it in instead of pressing the button. It may have skipped a gear or two. Many cd drawers have a pin hole in the front put a pin in until it presses a switch and starts to open the door. You may have to try this a few times until you can catch the drawer and pull it open. You have to dismantle the door to sync the gears properly.
Nov 18, 2013 | Excalibur Electronics Toys
I just received my brand new talea giro plus in the mail today. went thru the instruction manual and set everything up step by step. when i turned it on the very first time the red exclamation point is...
I had a similar problem. I opened and closed the water tank, the top coffee bean coffee and the dreg door several times. I even 'stirred' the coffee beans a bit. Finally, after simply taking the coffee bean cover off and putting it back on, the light went to green. Even now, several months later, I sometimes have to open and close everything to make the green light come on, although it seems to be getting better with age. (like me :-))
Apr 27, 2011 | Saeco Talea Giro Espresso Machine
Door open alarm sounds and door open indicator blinks, but refrigerator door and freezer drawer are closed. Alarm stops when you press Alarm Off pad, but door indicator continues to blink until it times...
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Viking Professional VCBB363 Bottom Freezer...
Paper jam Brother HL-5050
1. Turn off the printer. 2. Remove any paper trays. Inspect them for wrinkled or damaged paper. 3. Also open the back cover of the printer if this model has one. 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it. 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside. 8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. 10. see alternative if the problem is still not solved. alternative : Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 05, 2009 | Brother HL 5050 Laser Printer
Saeco Magic De Luxe Espresso Machine Control Panel Doesn't Work
Do you have any of the left 3 lights on the top row? If you have the one that looks like 2 arrows pointing towards each other do this
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
May 17, 2009 | Saeco Magic De Luxe Espresso Machine
No response from control panel
Try this
Apr 17, 2009 | Saeco Magic De Luxe Espresso Machine
Upon power up error code CH is displayed , with second drawer
The steady CH indicates an open right side door. Being that the tray 2 is lit up it could be the side door for the second tray and not the one on the main body. Pull tray 1 and 2 out completely and make sure there is no paper stuck in the machine behind where the tray goes. Double check that both side doors are closing properly and that nothing is broken or missing in that area.
Mar 21, 2009 | Sharp AR-5316 Advanced Digital Imager...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fellowes Intellishred SB-89Ci Shredder Logo
291 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
