Dell Dimension 4500 PC Desktop Logo
Posted on Jun 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color display problem
I have a 4500S Dell and recently loaded Windows XP Pro onto it. It has come up with a problem with the color display that I do not understand or know what to do to solve the problem.
The color grid displays on 4 colors and says it is the max setting if you go to the settings box for the display unit. It had fine color before that happened. Could XP Pro have caused this problem and how does it get fixed?
Jim
Anonymous
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Jun 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
119
Questions
Helped
52999
Points
219
Seen this problem numerous times firstly you have to install your graphics accelerator driver and restart you system if that does not work then you will have to re install you windows operating system maybe even install a different version if you have one and then update to the one you wish to use. this problem is caused by you os not being able to recognise the graphics interface chip on your motherboard but try above and you problems will be solved. thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
2070
Points
29
You need to download and install the video drivers for it. Look in the device manager and you should see a bunch of yellow exclamation points. That means the drivers are missing.
Go to support.dell.com and put in your service tag and then find the drivers you need.
This is the direct link to the drivers for your model.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_4500S&os=WW1&osl=en&catid=&impid=
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 326 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
326
Questions
0
Helped
169068
Points
574
Goto the manufacturers website and see if there is a video driver for the XP os. After getting the driver U can goto the display properties and update the driver.
Anonymous
Level 2:
Scholar:
  • Expert 125 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
125
Questions
0
Helped
62331
Points
362
Display stopped working than recovered
first check for a virus or malware
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
2answers
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
When I start up my MacBook Pro the display colors are all messed up (it it is only using 32 colors). I recently installed Windows XP using Bootcamp. If I start it up in Windows, the display colors are...
It is likely that some program has grabbed (allocated) a good part of the color table. This used to be a problem with 256-color color tables--be sure you are set to millions of colors--Windows could be changing this. Try starting up with the shift key down (safe boot) and if this works, you will need to turn off some program that are being started up automatically. You may need to go to Terminal and look for the resource file ".bashrc" or ".cshrc" (pronounced sea-shark), which could be starting other programs, although I didn't find one on my machine just now. Use the "ls -a" command to list all including the hidden ones beginning with period. I use non-hidden files when I invoke certain Unix programs, just use ". program-name" in the bash shell, with no quotes, of course.
-Ken -Ken
Windows media is very dark aqnd color is blurred
Techguru2009: You need to install a third party decoder. If you have then uninstall it and reinstall. You might have a conflict with the video codecs.Let me know if this helps.
Installed New RAM, Now Have Display Problems (color)
It appears something has happened with the video card or connector especially if it displays fine with the onboard video and original memory. Disconnect power and reinsert the video card into it's slot.
2answers
Dell c400 upgraded to xp now it won't boot up
you have toboot xp in the dell they are not interchangable you have load xp withit inthe dell or the dell wont work
sorry to be the bearer of bad news
2answers
Dimension 4500S
hi!,
I hav a solution 4 u . Ur LCD monitor's wires of ur Laptop Has gone loose , U can just give ur lappy 4 a servicing.
byeee........
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
