Question about iLO V27DMBX Television
I have the 32 in. lct32ha36
I have cable my wife turned off cable box then the remote for tv now i turn on cable box and tv won't come on the red light is on but won't turn green i hear a wine like it's trying but it won't turn green or on
  • 2 more comments
  • pnccoverings Jul 03, 2008
    was watching videos was working fine turned off tv now does not come on only humming sounds
  • Anonymous Jul 05, 2008
    I have the same problem on two 32 " ILO POS.
  • debsdignity Jul 12, 2008
    i have the same problem it started slowly first i had to unplug tv then wait 20 min than plug it back in that worked three times now it doesnt work and cant get the red light to turn green. bought the tv at walmart in pa
  • lonnienjobry Jul 15, 2008
    We have an ILO 32in flat panel we bought at wal-mart a year ago. It has given great service until recently. We turn it off at night and when we tried to turn it back on, the red light in front flashed but the green light never came on. I unplugged it and after several tries, it finaly came back on. Not it will not come on at all and the red light flashes when I try to use the remote but thats about it. It Still doesn't come on. How can I trouble shoot this set to try and find the problem?
    Thanks,
    Lonnie & Jo
My name is dennis am a tech for over 20 years you have a bad power supply I have repaired about 16 of these hilo tvs and i put together a kit for the pover supply my # is 716 798 4393.
Posted on Jun 05, 2008
Protron PLTV-32C, 3 years old Have always used the cable remote to turn on TV. Cable turns on. TV will not turn on but, redlight is on. Tried powering manually, tried both the TV remote and the cable...
Tries unplug the tv and the cable box about an hour and replug both.See if the tv reset it self and the cable box reboot it software.Not,than the Tuner board is dead,that the board the coalax signal cable plug into it to get the broscasting signal.
Jul 14, 2010 | Protron PLTV-32 Television
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
  1. Turn on your TV.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
I hope that helps.
Jul 18, 2009 | Innovage Jumbo Remote Control
32 ilo lcd
most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
Mar 30, 2008 | iLO LCT32HA36 Television
Programing codes for a Protron TV
The codes for the 32' Protron are 1004 or 1011. However be aware that this may disable your defaults permanently. When we had the cable installed they changed the codes but on doing so, the TV was useless. On power up the led will go from red to green, then go back to red instead of giving a source option. Customer service is agravating and useless; this is Chinese company that is using the name ProtRon to ride on the better make of Proton. We bought it through ShopNBC, definitely a big mistake since they are of no help either. We have taken the TV to a repair shop; they say its a main board but they are having extreme difficulty getting help from Protron; only delays and excuses. There are more issues riding on all this that has prompted my wife and I to seek a class action.
Feb 20, 2008 | Protron PLTV-32 Television
Remote code for an 32" ilo tv
Try the codes for Emerson TVs.  I've heard they work, but I haven't checked myself
Jan 20, 2008 | iLO LCT32HA36 Television
32" lcd ilo tv
Call 800-726-4405 - but you will have to ship the television to California at your expense to have it repaired or replaced.
Nov 16, 2007 | iLO LCT32HA36 Television
iLO V27DMBX Television Logo
47 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
