Question about Proscan 40LD45Q TV
Do not have owners manual. Cannot get it fro exwife. I can not locate the audio out from the TV to the home theater system because it is labeled in an Oriental language on the back of the TV. When I had the manual it depicted the rear view with english labels. Can you show me that page from the owner's manual.
  • 44 Answers
Try this:
http://downloads.devicemanuals.com/dl/P/proscan/40LD45Q-UM-English.pdf
Posted on Oct 12, 2010
Instruction manual for a RCA Home Theater System RTD 3136
The speaker jacks are labeled on the surround system.
front left front right
sub woofer
(can be located either side)
center
left rear right rear
tv= audio out ( red/white ) to surround=audio input ( red/white)
yellow is video, not needed for sound
Feb 18, 2014 | RCA Rtd3136 5.1 Channel Home Theater...
Need help setting up samsung Ht-tx 72 dvd home theater system jus to get sound to come from tv thru the surround sound speakers
Look in the manual...
http://www.retrevo.com/support/Samsung-HT-TX72-Home-Theater-Systems-manual/id/2771dj593/t/2/
The TV >>receives<< Video and Audio from the Samsung. Page 19.
The unidentified TV with its unknown audio capabilites has a manual somewhere, too.
How many TV's are actual audio sources?
If the TV is actually a root source of programming (say, through its own antenna) you can run cables from it to the Samsung as you would any other audio source. If the audio really comes fro ma Cable Box THAT is where the best TV-related audio will come from.
Jul 16, 2011 | Samsung HT-TX72 Theater System
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
Connection
Your TV should have an audio output which are red and white colored jacks, labeled audio out, on the back of your TV. There are also be the same inputs on the home theater system. You would have to buy an RCA cable which is inexpensive. You can then connect the TV from the audio out jack to the AUX 1 or 2 jack on the rear of your home theater system. Then select the AUX 1 or 2 input option (the one you hooked the cable into in the rear) on the home theater system, and you should be in business.
Feb 05, 2009 | Philips HTS3450 System
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
Instalation
You need to check the back of your home theater for an input jack (it could be labeled tv in or aux in). Then check your tv for audio out jacks. Use a quality rca patch cable from the tv to the home theater. The tv may need to be switched from variable to fixed audio out on the audio menu of the tv. If it is an older or inexpensive tv in may not have the output capabilities.
Jan 11, 2009 | Panasonic Home Theater System System
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Proscan 40LD45Q TV Logo
161 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
