Question about Panasonic PT-43LC14 43" Rear Projection HDTV
I was told that my bulb is good however the balast is bad. where can i purchase this and are there instructions on replacing it?
  • Panasonic Master
  • 8,457 Answers
Turn on the tv now,hear alot of clickings?Yes,the Ballast board is dead.The only function of the Ballast board is to ignite the projection lamp.Tries websites like Ebay.com,Partstore.com to buy a ballast board for the replacement.Instructions came with the board,how to replacing it,don't know?Try You Tube.com video.Type in ur tv make,model and the problems.Might have some bodies giving u advises or there are videos tutoring u how to do it.
Posted on Oct 12, 2010
I have a 2004 lincoln town car. Headlight needs repair, bulb out. Ny mechanic states balast is shot. Already replaced bulb. Is there a balast on this car ?
The stock halogen headlamps that came with the car DO NOT use a ballasting system. However, many owners upgrade to aftermarket xenon headlamps for a brighter output which do require a ballast.
Nov 26, 2016 | Lincoln Cars & Trucks
My right side headlight not working on A4, 2007. Install new H7 bulb from Audi but it did not work. I install the right bulb into the drivers side and it work. I suspect an electrical problem. Possible no...
if it is a hid light system they are famous for the balast going bad. follow the wires from light bulb. if they go into a box then its a hid system and it is the balast box that needs to be replaced. also check the fuses, sometimes there are seperate fuses for each headlight.
Mar 09, 2013 | Cars & Trucks
Do not know how to replace pl 13 bulb in nonintegrated balast
A few Panasonic's did this--the two are actually one unit.
Apr 28, 2012 | Televison & Video
Tanning Bed. I have 6 Balasts on my Solar Storm 24R Tanning bed. I am having difficulty in locating the replacement elctronic balast. They are double balasts operating 4 bulbs each. I can not identify the...
You just need a good electrical wholesaler and they will either have them or get them for you.
Or buy direct from Solar Storm Parts
http://solarstormparts.com/
zip code 71220 Google Search
Jun 20, 2017 | Kitchen Ranges
After replacing a bulb, when power on, it flash first green and goes to flash red continue to flashes red about 5 flash each time what should i do?
5 is a lamp driver fault, could be a poorly seated bulb or a bad ballast. Usaly it is a bad ballast. Previous bulb failure could have dammaged the balast.
May 07, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
HAS SOUND BUT NO PICTURE
okay the reason that the its turning off could be the fan isnt spining fast enoug hold your hand at the back of the tv to feel where the exhaust air if isnt good enough to help cool off the bulb then the fan may need to be replaced also the balast could be going bad and last check the power supply that feeds the balast make sure its a constant dc voltage
Mar 28, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Oct 23, 2009 | BenQ SP820 Projector
4-bulb flourescent fixtures flickers before coming on completely
The problem may be related to the balast unit in your light fixture. Check under the cover plate in the middle of the fixture and look for a rectangular (usually black) box. If it has any brown liquid leaking from it then it definately needs to be replaced. Read the label on the box and record the values. Take your stats to the local electrical shop and buy a replacement balast. Installation will require the breaker to be shut off to the circuit. Be absolutely sure you match the wires before attaching them together. Disposal of the old balast must be done through your local recycling center. The material in some of these is quite dangerous.
I would problably suggest contacting an electrician if you are at all uncomfortable with handling a re-wiring job. Good luck with your situation.
OpenSource13
Apr 11, 2009 | Lowel Light Lowel Flou-Tec 450 Fluorescent...
Samsung HL-p4663w/3 lights
go on the samsung website get the part number and then go on ebay and purchase the ballast. its half the price. pull out lamp assembly and right under it is the ballast. 2 or three screws hold it in. and there are 2 plugs that need to be undone. its very easy. hope this helps. i did it in about 15 min
Jan 23, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Light Engine?
try removing the lamp and inspecting it if it's not shattered inside ,chances are it's ok and you might have another problem ,possible balast fault,that drives the lamp assy. look for fan operation also.
Sep 07, 2007 | LG 52SX4D 52" HDTV
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
