My aser 7730 will not turn on? When the charger is plugged into the laptop the light on the charger flickers? Is this a mother board issue or power jack or what ? Help !
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Oct 12, 2010
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
No Power on Hp 620 Laptop
If the battery does not charge then the problem is likely the charger.
If you can borrow a charger instead of buying a new one you can find out for sure if the problem is the inside the laptop its self or the charger.
Remove the battery and hold down the standby button for a whole minute to drain any remaining power in the model. replace the battery , attach the new/borrowed charger lead and see if any activity happens ie, sound, lights...ect. This is the first thing someone does in a repair shop and its to diagnose where the issue is comming from.
Feb 21, 2014 | HP Computers & Internet
My ibm laptop's mother board cannot power on, please help me solve it
The most likely problem is that the onboard power supply has failed, usually a capacitor has burned out. Or it could be a loose DC supply socket (they only need to have one loose pin on the motherboard.)
Nov 01, 2012 | IBM Computers & Internet
I am having a problem with a hp pavilion dv4. When it is plugged in the charging light will flash when i try to power it on the other lights on the case flicker and die . and if i plug in the laptop...
had a similar problem,and I resoleved it via a bios flash..this allowed the hardware to be fully recognized and to perform the specified role.For some reason,the bios software for this version seems to corrupt after several years. I have had my machine for the last four years..until it recently started giving the issues,it had no problems.
Jun 06, 2011 | HP Pavilion dv4000 Notebook
I cannot power up my laptop. the lights come on it makes a beeping sound then the lights flicker. it sounds as if it is trying to start up but it wont. please help......
Remove your battery and make sure that the battery voltage on it corresponds to the reading on your multimeter. If not replace and plug in the adapter/charger Now check the voltage at the battery terminals. If present then insert battery and allow the battery to fully charge as indicated on the LED. If the laptop does not work with the adapter plugged on, then the fault can be in the mother board section, possible areas can be the power supply, regulator and processor.
Jan 07, 2011 | Fujitsu Siemens AMILO Xi 1546 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
My Pavilion tx2635ea won't turn on at all! When the power cable is plugged in it lights up where the ac adaptor plugs in but when I slide the power switch to turn the laptop on nothing happens at all.
If you have multimeter then check the output voltage of the charger, if charger is not working then replace it, if charger is working then there must be a problem with mother board, try to contact some reliable repairing engineer.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion tx2500z Notebook
Toshiba equium l10, won't do a thing!!
The cheapest thing to do is to try and replace the charger. But I would not rule out the mother board.
Feb 04, 2009 | Toshiba Equium 7100S PC Desktop
Computers & Internet Logo
David Payne
David Payne
