Question about McCulloch Garden
My mcculloch 600068c starts and idles but when given gas it sputters and stops what is the problem? I replaced fuel line rebuilt the carbuerator new sparks plug. It has been suggested that there if a reed valve but where I don't know. It just acts like it is not getting enough gas.
  • dkratz2 Oct 13, 2010
    we have tried all the suggestions in your solution and it still will not continue to run when revved
  • 10,865 Answers
Hello. Generally, this problem is caused by a little gunk somewhere in the carb. or the engine. Get an assistant and a can of aerosol starting fluid. have your assistant squirt some fluid into the air intake to keep it running for a minute or so to clean the problem. Joe
Posted on Oct 13, 2010
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Start your carb adjustments by doing the following. Turn the LOW needle jet closed until it just closes. Then open it 1.5 turns. Make your adjustments on the LOW needle only for the moment. The goal is to adjust the LOW needle so that as you apply the throttle that it does not stall. Make your adjustments in less than 1/8 th turn increments. If it gets worse as you adjust the carb reverse the direction you are turning the LOW needle.
Once you start to notice that you no longer have hesitation increase the engine speed to max and adjust the HIGH needle until it just stops missing at FULL speed.
If by chance none of your adjustments make any difference... Open the carb base and check the position of the float needle tab on the diaphram. Bending it slightly DOWN (in 0.002 increments) adds more fuel and bending it UP causes less fuel flow.
Most of the time fuel starvation is caused by air being introduced into the fuel system or just not enough fuel through the float needle valve on the top of the diaphram. It can also be the fuel tank pick up tube / screen is clogged. Most of the time if there is a pick up tube problem it will lean out at high rpm.
Watch your fuel lines for any signs of air bubbles. If you see ANY bubbles at all after initally bleeding off the air there is still air being introduced into the the fuel supply and you wil have to find out why.
Lastly...I have seen loose fuel manifold tubes on carbs cause this problem. It is really really rare but it does occasionally happen. Make sure the tube on the side of the carb that mates the fuel tank line to the carb is tight and not introducing air into the carb.
Here is a fair dissambly video for a walbro carb:
I do not believe you have a reed problem at this time. If you did have a reed problem it would not even start.
And here is the re-assembly:
Posted on Oct 12, 2010
  • Kelly
    Kelly Oct 13, 2010
    Here is a note about the float needle setting:
    Float, Needle & Seat Setting
    This critical setting is the primary way to adjust mixture on some Walbro carbs such as the WG8 used on Top 80 motors. Apparently Walbro offers a setting gauge to properly set the height of the lever for each model. Without that gauge you'll have to use trial & error which is a pain since you must open up the carb for each adjustment. In general, the lever will be parallel to the carb base. If the lever is too high, the mixture will be rich, too low and it will idle ok but be lean at midrange and above. It may also run the float cavity dry at full throttle and die, regardless of your highspeed / lowspeed needle settings.
    Take good look at this picture:
    http://www.footflyer.com/PPGBibleUpdates...
    Note the float needle lever position.
    Typical Walbro Problems
    They're really quite reliable, but when problems arise, they are frequently one of these.
    • The small filter on the fuel-intake side clogs. Clean it out by removing and spraying carb cleaner through in the opposite direction of normal fuel flow. Re-insert using a pencil eraser.
    • The float diaphragm degrades and reap havoc on tuning, especially the low end and idle.
    • The internal needle valve WILL leak when they get old or worn out. If you notice gas dripping from your carb, or if the idle gets unreliable, replace the needle valve and adjust the lever even with (or slightly below) the carb housing if you don't have a gauge.
    • The fuel pump membrane gets stretched and/or sometimes hardens from the gas. It needs to be replaced occasionally. If your pump doesn't pump properly, (1) it will be hard to start (2) it will tend to run lean, and opening the needles won't help much if any.
    • Erratic idle, or no idle is often traced to a bad internal needle valve, bad float diaphragm, bad pump, and most common... **** in the carb. You may also have an air leak!
    • The pop-off pressure is out of the normal range. About 12 PSI is normal. Pop off pressure is how much pressure is required to pop the main-jet needle off of its seat. The fuel pump pushes fuel against a spring. Either having the wrong spring, a cut spring or stretched spring can affect this pressure.
    • All Walbro carbs will run in any position, but they tune "best" as a side draft carb meaning the airflow intake is horizontal. The down draft position tends to run a little rich at idle, and the updraft tends to run a little lean at idle although it's easily tuned regardless.
    I am pretty sure your float needle lever needs adjusting / lifted up so that its at least level with the INTERNAL carb body or slightly higher. This is a tedious trial and error process. Also make sure there are 2 tabs on the float needle lever tht capture the end of the float needle. I have seen some that one of the tabs was broken on them that will do exactly as you describe your symptom.
    I know it is frustrating....! A few of these carbs have really thrown me for a loop even after several decades of working on them in my families' shop and a professional repair shop.
    Kelly
  • Kelly
    Kelly Oct 13, 2010
    If you have for sure tried everything in both of my posts and your sure that no air is being introduced into the fuel system; the only thing that I can think of that would make any sense at all is that one of the needle jet tips has broken off in the carb from being closed to tightly. Remove both jets. Inspect the tips of each jet to make sure that the tip is intact. Then with a bright light inspect the fuel metering orifice deep in the jet hole to make sure that a piece of the tip is not lodged in the orifice.
    I've been doing this for many many years.
    http://blog.fixya.com/index.php/2010/05/...
    Kelly
I have a 2008 Qlink Legacy. A couple days ago I was riding it when my CVT belt broke.
Hi, Noah and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
engine sputtering and dies below 10mph won idle
starts idles stalls giving gas Scooter Doc Forum
Bike idles perfect but dies when given the slightest amount of throttle 93...
Jul 23, 2016 | Qlink Legacy 250 Motorcycles
Why will my 86 mercury 9.9 motor will idle, but stall when given gas?
Did you use ethanol fuel in it?
If you did and you let it sit in there you need to clean your carbuerator, replace any rubber lines, parts, etc.
Jul 15, 2014 | Boating
Is it my fuel pump???? Sorry will post a vid soon but the description is exactly what it does...
Locate the fuel pressure regulator and remove the vacuum line and start the engine, inspect, if vac port leaks fuel , replace regulator, provided your vehicle is equipped with a vacuum operated fuel pressure regulator.
Jan 08, 2014 | Cars & Trucks
Sputtering and stalling S10
Did you put a replacement injector assembly in under the upper intake, this is a major problem with this model. How's your fuel mileage? If this is your prob you need to change it because the leaking fuel goes down in your oil pan, thins the oil and blows your engine. Check your oil, is it over full or smell like gas?
Nov 24, 2013 | 1995 Chevrolet S-10 CA Edition
My car starts and then sputters and die
It can be clogged intake manifold or issue with low fuel pressure or the problem is low battery voltage or issue with clogged fuel filter.Inspect all this basics.For more troubleshooting,click the link below and go through troubleshooting:----Stalls, Sputters and Pops Through Intake Manifold? http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Stalls and Stops While Driving? http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
No Idle and Stalling issues? http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
Vehicle starts then stalls and shutdown? http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Engine stalls when gas is given? http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
This will help.
Thanks.
Jun 05, 2012 | 2006 Infiniti G35
I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Oct 08, 2009 | McCulloch Garden
Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Aug 28, 2009 | Boating
Car shakes at stop signs, very poor gas mileage, and sputters whe
Try having your fuel injector cleaned, you can start with running fuel injector cleaner though your gas tank and if that does not help then you have to get it cleaned out professionally or even worst have the injector's replaced if they are bad.
The other thing that will give it bad fuel would be a bad air intake temperature sensor go bad, as for the ruff idle that is common to a dirty or stuck EGR valve.
Good luck and keep me posted, by the way, what kind of Garage did you take it too? And are there and DTC codes from the ECM?
May 26, 2009 | 2002 Buick Regal
1988 gmc v 3500 350m carbuerator
its possible that there was something in the tank or line that plugged your new filter. try changing it again
Oct 10, 2008 | 1988 GMC K3500
Garden Logo
161 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
