Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
My GE TV model D52GW12 works fine, but now the color seems to be faded. The greens and reds watching a baseball game are off and the picture. Not sure what to replace or if it is worth it. The picture and itself an tv work fine otherwise.
  • GE Master
  • 11,800 Answers
This projection tv uses 3 small CRT tubes - the faded image you describe is an absolute textbook example of how a tv looks like when the tubes have aged. The only thing you can do is to replace the tubes. This is an quite old tv for which finding new tubes will be extremely difficult and expensive. - around $200 for one.
Since spending over $600 on an old tv doesn't seem reasonable to me you should accept the fact that this tv has reached the end of its life and start saving for a new one.
Posted on Oct 12, 2010
My picture is in green. The convergence seems to work just fine. Why would my screen be green?
You might have the yellow for video, white, and red for audio (composite connection) plugged into the component plugs green, blue, red for video, white, and red for audio (component connection) somehow combined together on the back of your TV to whatever source your watching.
It should be color to color from your source to your TV.
It's that or only the green plug is plugged in for the component video. Hope this helps.
Jun 20, 2011 | Zenith R57W46 57" Rear Projection...
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
Screen fades to blue after 10 mins of viewing. Sony kp-57hw40
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
I hope this helps you!
Fare well. :)
Iconoclast
P.S. you can also clean the mirrors and dry dust while you have it open.
Jun 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen projector un aligned
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
HD PICTURE
Use your input button on your television's remote control.... you should have plugged the wires into the COMP 1 area on the back of your TV.  You will also need to make sure your red and white audio cables are plugged in as well (Five total plugged wires) Press the input button until you see COMP1 at the bottom of the screen... there you will find your picture and sound.
Oct 19, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
