Question about Brother HL-2040 Laser Printer
No lights on but just stopped printing. Changed ink, checked paper all ok what next.
  • 863 Answers
This model printer doesn't use ink. It uses toner, because its a laser printer. Pull out the toner cartridge and replace with a new one. Also, press the power button to shut off and also unplug the printer. Wait a minute then plug back in and power back on.
Posted on Oct 12, 2010
  • Poppy Chulo
    Poppy Chulo Oct 13, 2010
    If you don't feel like replacing the cartridge toner so soon, get you a piece of black electrical tape and tape both sides of the toner cartridge where you see two circular looking plastic things. The bastards at Brother shoot a laser through this thing on the sides. When the toner gets too low that will trigger the lasers to make the printing quit or to make the lights say your out of toner. This little trick should let you squeeze another 250 pages out without replacement.
Printer will not print pages. Blank paper comes shooting out
clean heads and align clean cartridges,next time use original dell cartridges no refills or over filled ones
Apr 24, 2015 | Dell Photo 926 All-in-One Printer
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
Changed cartridge--now paper gets stops by cartridge carrier. turned on and off, reinstalled cartridge, cleaned roller.
Press the OK button.
- If paper is being fed at error occurrence, the
error is indicated after the paper is ejected.
- If the error occurs, the print head alignment
values are not changed.
- After exit from the error by the OK button,
the automatic print head alignment will not
be re-done.
The error will occur when the print head
alignment pattern is not printed due to no ink
or non-ejection of ink.
Oct 11, 2009 | Canon PIXMA iP1800 Photo Printer
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
Our printers epson c42ux red light is on stand still
A permanently on red light can mean several things. If the green light is also ON, it means that you heve no paper loaded, an empty or faulty ink cartridge, or a jammed paper feed. I presume you have loaded paper. You say you have changed the ink cartridges. Note that BOTH cartridges must have ink for the printer to work. The simplest way to check this, or to check for a faulty cartridge, is to try another new set of cartridges - compatible cartridges are very cheap on EBay - about £3 a set in the UK.
To check for jammed paper, remove the paper from the sheet feeder and look carefully inside it, and inside the printer (lift the lid) for scraps of jammed paper. Remove any you see. Press the ink/paper feed button and see if it goes through a paper feed cycle. Reinsert the paper and try it again. If it works, turn the printer off and on again, and it should now be OK.
If the green light is OFF, it means you have a Carriage problem, i.e. something is fouling the print head when it tries to go from side to side. Check this with manual movement. Turn the printer off. After a few seconds, turn it back on again. As soon as the print head moves, pull the power cord out of the back of the printer. You should now be able to move the print head across to the left side (gently!) by hand, then move it back to the right and see if it will go fully into its parking bay at the right hand end. You should be able to tell if someting is hindering its movement anywhere.
Please report back with a new comment if none of this solves the problem.
May 31, 2009 | Epson Stylus C42UX InkJet Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Epson stylus R 310 "general error" message
Those generic refills are not worth i, plus they may void the warranty. Try removing them and cleaning the little circuit board sensor. Make sure leaked ink hasnt covered them.
Oct 22, 2007 | Epson Stylus 1000 InkJet Printer
Brother HL-2040 Laser Printer Logo
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
