Question about Craftsman Air Tools & Compressors
Craftsman spray gun (919155190) tip is leaking fluid when trigger is NOT depressed. This happens at 8psi as well as 40psi. If I turn the fluid control knob "off", then there is no leak. If it is even a little "on", there is plenty of leak. Help!
    Sergeant:
  • 270 Answers
The tip as well as the pressure, are regulated in part be the viscosity and consistency of the product being sprayed. If the orifice is clogged, then it will not shut off properly and will cause splotchy spray when turned back on.
If the mixture is not smooth, the lighter part will leak out while the heavier parts remain behind... This of a lumpy gravy, the lumps hold the orifice valve open while the gravy leaks out.
Remix your solution, and pay attention to the viscosity requirements for your tip.
Good luck and don't forget to vote.
Posted on Oct 12, 2010
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
Bostitch just blows air when trigger is pulled
Air leaking from trigger when attempting to fire the gun is normal and should cause nailer to fire, however if the trigger pin is not depressed all the way in,the gun may not respond. Easy test. Remove the nails and remove the trigger. Connect the gun to air and quickly depress the valve pin all the way in with finger. If the gun fires, adjust the safety foot so that the trigger pin is depressed all the way in. If the gun still does not fire, then remove the head cap and pull out the headvalve. Apply plenty of white grease to orings and retest. If the gun fires, then replace the headvalve orings. When the headvalve orings are worn, air will leak from bulkhead chamber to the headvalve chamber causing the gun to not respond to the trigger. The addition of grease to worn orings will make them temporarily seal. Good luck
Jun 16, 2016 | Stanley Bostitch N66c1 114"to 212" Coil...
How to repair of air leaks out in the plug in of hand held air tools when i depressed the trigger
This problem occurs when the orings in the headvalve and/or trigger valve are worn or just needs lubrication. This also happens when the safety foot does not push the trigger valve all the way in. Easy test. Remove nails and air pressure. Remove the trigger exposing the firing pin on the trigger valve. Connect air and with a very quick motion, depress the firing pin all the way in. If the gun fires adjust the safety foot. If the gun does not fire, remove the head and pull out the head valve. Lube orings in head with plenty of white grease. Reinstall head and test. If the gun fires, time for oring kit or just keep applying grease. If the gun still does not fire, most likely problem is trigger valve orings. Good luck
Oct 13, 2014 | Air Tools & Compressors
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Spray is pulsing
You most likely have a leak at the seal for the neddle try tightening the nut at the trigger if that dosn't work take it apart and check the seal replace if required .This should stop the surgeing at the tip
Apr 25, 2011 | Binks Paint Spray Gun Repair/rebuild Kit...
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Gun will not stop spray when trigger is released
Fluid tip worn, pressure too high or the ball has come off.
Try EXITFLEX in Bournemouth, always found them very helpful, but that was a while ago!
Dec 17, 2010 | Wagner GX10 Spraytech Airless Spray Gun...
After switching from a 1.2tip to a 1.4 tip when i
adjust the knob that holds the needle inside the gun
Mar 17, 2010 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
Air Tools & Compressors Logo
202 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
