Question about RTO Chrome YL88 Keyless Electronic Digital Door Lock
Need to reset the entry code on a YL-88 stainless steel lock.
  • 10,319 Answers
Technical Details
  • Single user codes are changeable; You can use the emergency module if the battery is down
  • When the door closes the lock will lock; The inside lever is always free to turn and open the door
  • All user codes can be deleted in one easy operation; Entry access using "ON" button by MasterCode
  • Battery back up module in case of emergency; Uses 4AAA batteries
  • Visual and audible entry LED indicators
> See more technical details
Posted on Oct 17, 2010
  • Problem Solver May 05, 2012
    Okay Guyz n' Galz...Finally I solved this by lot of iterations. I have YL-88, YL-68 and D77 Digital locks. They are all made by Yili from China with buttons placed circularly. Warning, to reset it might not work on button placed in square pattern (YL-99).
    Default master code is 0123# all the locks mentioned above.
    Now to reset the master code, press and hold the reset button(red) for 2-5 secs on the battery pack, and remove one battery. Release reset button. Give 5 to 10 secs. Then press and hold reset button first, put back the battery into it.
    Now the lock is reset to factory default. i.e., 0123#.
    Warning: Make sure the default works before you close the door and lock.
    Now to apply new master code: Enter default 0123# and wait till the sound is gone and the light is still lit. Start your new code starting with '0' and end with * key (not the # key). It will beep twice. Your new master code is ready to use. Now if it does not beep twice. Try from the begining with default code.
    Enjoy
    Your'
    Problem solver!
The oven door is locked
Hello Berna Morgan, thank you for your inquiry!
Based off the information you have provided the door on your Frigidaire oven is locked. If you check on the control panel of your oven there should be a clear or cancel button, hold that down for three to five seconds. If that does not help unlock your door I would suggest performing a power reset and you can do that flipping the household circuit break for roughly ten minutes. That should provide a factory reset to your oven. I hope this information is helpful to some degree. -Matt
Feb 10, 2015 | Frigidaire FGB24L2EC Built-In 24 Gas Wall...
How to open Y130 - Stainless Steel Padlock without ihe key
Your lock will need to be seen by a locksmith, who can hopefully pick it open for you, or possibly open it by impressioning. If not it will have to be drilled.
May 19, 2014 | Yale Y130/70/116/1 Marine Grade Stainless...
My haier remote model # YL-M05, got locked and I dont know how to unlock that please help me.....
use a paper clip to poke into the reset hole,the unlock button is used to lok the buttons,press it once for lock again for unlock
Sep 03, 2013 | Haier YL-M05 Remote Control AC-5620-35
How do I get a manual for YL88 electronic lock
Enjoy
Your'
Problem solver!
Jan 04, 2012 | RTO Chrome YL88 Keyless Electronic Digital...
How to reset codes on a yl88 keyless electronic digital door lock lost the manual and cannot work it have no emergency module
Enjoy
Your'
Problem solver!
Oct 02, 2011 | RTO Chrome YL88 Keyless Electronic Digital...
How do i reset codes on ice/water dispenser. Code button is locked
Try first reseting the refrigerator by unplugging it for 30 minutes. That should reset it. Let me know if it doesn't, you might have a bad control panel otherwise.
Benjamin
Nov 05, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Codes flashing on door screen after power blip
You had a power surge due to the storm, unplug the unit for 5 min's and see if it resets the faults.
Jul 09, 2017 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
I lost the manual and i can't reset the clock on the machine. how do i do this?
reference: Setting and Adjusting the Clock • The machine must be “off“. • Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“. • Adjust the hours in steps by pressing the h/min button (n). • Press the prog button : the minutes will blink“ XX 88“. • Adjust the minutes in steps by pressing the h/min button. • Confirm the setting by pressing the prog button.
Mar 17, 2010 | Krups FMF5 Stainless Steel 10 Cup Coffee...
Panel showing 88 88
You can try unplugging , wait a few minutes , and plugging back in . If that doesn't work , then the main control board , located on the back of the refrig ( behind an 8 " X 10 " panel ) , was damaged by the power surge , and needs to be replaced .
Nov 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Dishwasher will not start
push and hold that button in for 3 - 5 seconds i believe the control was locked. let me know if you need further assistance or if this solves the problem
Nov 30, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
RTO Chrome YL88 Keyless Electronic Digital Door Lock Logo
269 people viewed this question
Top RTO Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a RTO Lock and Locksmithing Expert? Answer questions, earn points and help others
