Question about IBM Office Equipment & Supplies
How do i stop the reprint from going and I need to correct the typing already on paper that was repeated
  • IBM Master
  • 3,594 Answers
Go to lexmark.com, click on support you will find a manual bthere.
DickyO
Posted on Oct 18, 2010
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
How to type in a name and have it automatically type on forms
The WW1000 has a reprint key on the upper L. of the keyboard.
This key will reprint anything that has just been typed.
Turn the T/W off and on to clear the reprint.
Insert the form, type information and return.
Insert the next form, press code and repeat print the info should repeat.
If you go to lexmark.com and click your way to publications there is a downloadable manual there.
DickyO
Jan 11, 2010 | Lexmark Wheelwriter 1000 Typewriter
Double printing
HP do not use fuser oil. The upper roller is made of a non stick coating. When this begins to waer the toner sticks to the roller along with excess paper dust off the paper.This is what will cause a repeat image on a page. You need to swop the fuser unit to cure this fault
Oct 01, 2009 | HP LaserJet 4250n Printer
Pitch changes midway through job and randomly reprints over lines
Check the cable. It looks like some sort of interference over the cable. Make sure it does not lie next to power cable.
Jul 17, 2009 | Matrix Okidata 120V Printer
Can't turn off re print
If you use the SAPI (semi automatic paper insertion) feature before you type the info you want to reprint the reprint memory will only have what you typed after SAPI.
You activate SAPI by pulling the rt. upper bail arm fully forward.
DickyO
Sep 12, 2008 | Lexmark Wheelwriter 10 Series II...
Wheelwriter 2
Some personal WW have a reprint feature top L. hand key (RE -PRT) in green. This will only reprint what you have just typed. To get a true memory you need a WW 5.6.30,etc.
DickyO
Aug 19, 2008 | IBM Wheelwriter 30 Typewriter
Reprint
The first thing to do is to set the top margin. Insert the card using the SAPI semi automatic paper insertion, pilling the rt upper bail arm forward, space up or down to the top margin you want, press & hold the code key while pulling the doing SAPI the P/W will spin and reset the top margin.
Type info on card, remove card, insert next card using SAPI, Press code and reprint key and it will repeat.
DO NOT TYPE ANYTHING AFTER A SAPI OR THE REPRINT WILL CLEAR
DickyO
Jul 09, 2008 | Lexmark Wheelwriter 10 Series II...
Re-print full?
The reprint automatically stores as you type. I dont believe it can be turned off, however if you use the SAPI feature it clears and starts over. SAPI Semi Automatic Paper Insertion. When inserting paper pull the rt. upper bail arm all the way forward it will indert paper to preset position and clear reprint memory.
DickyO
Apr 16, 2008 | IBM Wheelwriter 30 Typewriter
Cx8400 printer
For the Cx8400 printer.
If the paper doesn’t eject fully, you may have set the wrong paper size. Press the Stop/Clear Settings button, then open the scanner and remove the paper.
Select the correct paper size before you reprint.
Have a good day!
please vote...
Feb 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Reprint last fax
JUST OPEN THE TOP COVER PUT IN NEW INK CAARTRIGE THEN FAX WILL RESUME PRINTING FOM MEMORY AS LONG THE POWERS WASNT TURNED OFF
Dec 31, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
20 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
