Question about Dell OptiPlex GX520 PC Desktop
Hi there! I have a problem with my Dell Optiplex Gx 520 Small factor PC. The CPU fan seems to be blowing faster than usual and its making a loud noise like a vacuum cleaner. Please help .........Jones........
    Guru:
  • 124 Answers
Try to check in the Bios if there's an option to adjust the fan speed of your CPU. If not try speedfan, its a freeware : http://www.almico.com/sfdownload.php
Posted on Oct 12, 2010
  • jjonesche2 Oct 13, 2010
    Thank you Natzki for your response.
    My Bios does not have that feature. I've downloaded and installed Speed fan but its saying ''NO SUPPORTED CHIP DETECTED'' I don't know what else I can try. This noise begins 2 second every-time I power on the CPU.
  • xeenomorf
    xeenomorf Sep 24, 2012
    Make sure the fan speed over-ride is not checked in the BIOS
I want a sound max audio driver for my dell optiplex gx 520 for window 7
Hi Heart44kille, Just saw your unsolved problem. Here the link to get your sound Max Audio Digital Audio driver:
www.driversforfree.com/omn_ofm_omd_dt/dell/optiplex/gx520/audio sound/drivers.asp
Oct 01, 2012 | Dell OptiPlex GX520 PC Desktop
Sir how two install a audio driver for dell optiplex gx 520?
If you go to this site, you can get all of the drivers for the Optiplex GX 520. Please make sure you select the correct version of Windows that you are running (Windows XP, Vista, or 7). Then, select "Audio" from the drop-down list, and download the driver for ADI 198x Integrated Audio.
If you're running Windows XP, you can just click here to go directly to the driver download.
Once you download the driver, just double-click the file to start the installer.
Aug 09, 2011 | Dell OptiPlex GX520 PC Desktop
Dell optiplex gx 760 intermittantly freezes. Different applications, some browser based some not. Usually as mouse is being used to select a menu or toolbar option. Video, mouse, and keyboard freeze. PC...
Make sure all your systems are updated. You should be able to check through "Control Panel" and click update icon. It should show all is updated or a need for updates. You can also click on check for updates to make sure.
Mar 08, 2011 | Dell OptiPlex 780 Desktop Computer 1 x...
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
For our Dell Optiplex GX 520 Desktop, Very loud noise is coming from fan, we tried to change the fan and even updated bios, but still the problem continues.
Hi, I am Steve, lets get you some help
When you say you tried to change the fan I am guessing you did not manage to.
The computer has very few moving parts inside it so not much that can cause noise.
You have 2 real options
  • It is coming from the speakers/sound jack and something is wrong with the sound card. Cheek this by unplugging the speakers.
  • The fan is is the other option - firstly clean the fan and the air vents to see if that helps - if not replace the fan assembly.
Hope this helps.
Jan 22, 2011 | Dell OptiPlex GX520 PC Desktop
How do I know if this cpu has a network card?
The Dell GX270 small form factor has an integrated NIC card that is built into the motherboard.
May 15, 2010 | Dell OptiPlex GX270 PC Desktop
How much ram does a dell optiplex gx 260 support?
The manufacturer's web-site:
http://support.dell.com/support/edocs/systems/opgx260/
lists the maximum RAM that is supported by this Small Form Factor unit.
Nov 14, 2009 | Dell OptiPlex GX260 PC Desktop
I have Dell GX280 system. My Fan produces more sounds and runs fast. System Hangs while processing and performs slow, causes processor nore hot. I pasted the Heat Sink Paste on processor that resuls in low...
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Sep 09, 2009 | Dell OptiPlex GX280 PC Desktop
Problem withe dell gx280 fan and display
Unfortunately this seems so be a motherboard problem, Dell's solution is to replace the motherboard I'm not sure there's much you can do at home or work to fix this - if it's still under warranty get dell to replace the motherboard if not im afraid its the bin for it sorry
Feb 02, 2009 | Dell OptiPlex GX280 PC Desktop
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
767 people viewed this question
Alun Cox
